5th gen Front bumper fog light part number?
Postby conor2469 » Sun Jan 21, 2018 8:47 pm
Hey guys,
I sourced this front bumper yesterday:
minus the fog lights unfortunately.
Does anyone have the part number for these foglight units? I did a search but couldn't find anything,
Thanks in advance.
conor2469
Re: 5th gen Front bumper fog light part number?
Postby Magroo » Mon Jan 22, 2018 2:09 am
I have the same fog lights in my CS Bumper. I think they came from a celica st. I had to make my own brackets to hold them in place.
Magroo
Postby FC Zach » Mon Jan 22, 2018 6:04 am
Are you interested in a good-used pair? Where are you located?
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby conor2469 » Mon Jan 22, 2018 8:10 am
FC Zach wrote:Are you interested in a good-used pair? Where are you located?
I might be, do you have the correct set? How much are you asking? I am located in Ireland but I have an address in NJ that I can get stuff sent to.
conor2469
Postby FC Zach » Mon Jan 22, 2018 8:37 am
PM sent.
FC Zach
Images: 9
Postby shogun86 » Mon Jan 22, 2018 4:55 pm
Would you happen to have any photos of them mounted on your car? I also looking for a set of fog lights for my CS front bumper.
Magroo wrote:I have the same fog lights in my CS Bumper. I think they came from a celica st. I had to make my own brackets to hold them in place.
shogun86
Postby FC Zach » Mon Jan 22, 2018 6:51 pm
shogun86 wrote:Would you happen to have any photos of them mounted on your car? I also looking for a set of fog lights for my CS front bumper.
The lights that I have, I purchased with hopes of using them in my CS bumper but could not figure out a way to install them. I ended up ditching that idea in favor of aftermarket LED lights. *I've heard talk of people using the OE AllTrac bumper fogs but never saw any pictures, even after searching online for hours.
*Edit: I assumed all US Celica fogs were the same but I guess they are not after comparing pics of AllTrac and ST fogs, so maybe in the past I misheard what people were really using but regardless I couldn't find pics of installed lights in a CS bumper. .
FC Zach
Images: 9
Postby Magroo » Tue Jan 23, 2018 1:20 am
I used a couple pieces of abs plastic sheeting to Mount them directly to the bumper. I ditched all the metal brackets after fussing around with them and a welder for a few days and not getting the results I wanted.
I'll try to take pics later this week. It isn't pretty but its effective. Built it as a proof of concept just to see if it would work. They bounce around a little bit but that may be to the stiffness of my suspension. It just looks like those spaces needed some fogs and the celica st had the right shape and factory plug.
Edit. Just want to add I picked up a pair like this. No idea what the part number is.
https://rover.ebay.com/rover/0/0/0?mpre ... 2855999392
Magroo
Postby FC Zach » Tue Jan 23, 2018 4:08 am
I'm on the same page now. . . I just looked at the original post again but this time I realized that wasn't an AllTrac pictured (what I get for assuming). So with that said, the OE AllTrac lights I have are not what you are looking for. Sorry
FC Zach
Images: 9
Postby conor2469 » Tue Jan 23, 2018 7:52 am
FC Zach wrote:I'm on the same page now. . . I just looked at the original post again but this time I realized that wasn't an AllTrac pictured (what I get for assuming). So with that said, the OE AllTrac lights I have are not what you are looking for. Sorry
Ah ok, so the ones you have are this type, that sit behind the bumper vents?
conor2469
Postby FC Zach » Tue Jan 23, 2018 9:03 am
conor2469 wrote:Ah ok, so the ones you have are this type, that sit behind the bumper vents?
I guess so. . I believe that's what I have.
FC Zach
Images: 9
Postby underscore » Tue Jan 23, 2018 7:18 pm
Aren't they the same lights? The mounting brackets may be a little different but the lights themselves look the same.
Postby Magroo » Wed Jan 24, 2018 12:45 am
Stock alltrac lights are actually much larger than the st/gt lights. I'll see if I can take a side by side photo later. My work schedule and the weather havn't been cooperating lately.
Magroo
Postby Magroo » Wed Jan 24, 2018 4:03 pm
Here's some quick pics. Note the fog lights installed could use some adjustment. Just haven't had time to get in and fidget with them.
Magroo
Postby shogun86 » Tue Jan 30, 2018 2:28 pm
Thanks for the photos. I'm going to order a set.
Magroo wrote:Here's some quick pics. Note the fog lights installed could use some adjustment. Just haven't had time to get in and fidget with them.
shogun86
