5th gen Front bumper fog light part number?
Re: 5th gen Front bumper fog light part number?
Postby shadow_coupe » Thu Feb 01, 2018 7:50 am
Maybe I missed someone mentioning this but it should be noted there are 3 different foglight options's at play here. The original set OP is searching for are the 92-93 GT fogs. The ones @Magoo posted working in the CS bumper are 90-91 GT/GTS specific; slightly smaller and sharper corners than the facelifted fog's. The Alltrac units were as mentioned, much wider than both and specific to only the Alltrac/92+ GTS bumpers. Technically ST's never came with fogs unless they were added as an option... or you pillaged a junkyard like me :D
I went through the same trial and unfortunate error on both my ST and AllTrac trying all the options haha. Just wanted to save someone the same misfortune.
1990 Celica AllTrac
shadow_coupe
Postby FC Zach » Thu Feb 01, 2018 7:57 am
Great info, thanks!
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby Magroo » Thu Feb 01, 2018 2:13 pm
I think these might be the 3rd kind?
http://www.ebay.com/itm/162855975114
Magroo
Postby crackerjack » Thu Feb 01, 2018 2:45 pm
I figured out the fog lights after searching at the junk yard high and low.
This is what I found.
90 to 91 are the bigger ones that sits behind the bumper grill. I believe they are Koiku fog lights?(not sure of spelling)
92 and up Celica depending on month of production use and smaller version of the big boy but sits closer and not so far appart. Underneath the bumper, there are 2 sets of holes to screw both version in.
So yeah, they are all over the map.
crackerjack
Postby underscore » Thu Feb 01, 2018 5:03 pm
"Kouki" is generally used to refer to pre-facelift (for the 5th gen that's 90-91) and "Zenki" for post-facelift (so 92-93). I think the S-chassis guys starting using it first to try and sound JDM tyte or something.
Postby shadow_coupe » Thu Feb 01, 2018 6:06 pm
underscore wrote:"Kouki" is generally used to refer to pre-facelift (for the 5th gen that's 90-91) and "Zenki" for post-facelift (so 92-93). I think the S-chassis guys starting using it first to try and sound JDM tyte or something.
+1 on JDM tyte. I forget who had the sig quote on their profile that said, "Everytime kouki comes out of someones mouth it should be followed up with a slap to the face." Haha
crackerjack wrote:I figured out the fog lights after searching at the junk yard high and low.
Think you got the years mixed a bit but basically ;) Meant to do this last night, correct the info if it's wrong:
1990-1991 GT/GTS
1992-1993 GT
1990-93 AllTrac / 1992-1993 GTS
1990 Celica AllTrac
shadow_coupe
Postby crackerjack » Fri Feb 02, 2018 4:40 am
:D
Mine is a 91 Alltrac, so I thought thats when it came out cause it has the bigger lights behind the bumper grill.
didn't realize that non alltrac don't get the goodies.
My co worker have a 92 GTS and it has the bigger ones. He is the original owner with 90000KM on it and never
winter driven.
Cheers.
crackerjack
Postby shadow_coupe » Fri Feb 02, 2018 4:55 am
crackerjack wrote:My co worker have a 92 GTS and it has the bigger ones. He is the original owner with 90000KM on it and never
winter driven.
Woah. That has to be mint inside and out. Very cool. And yeah, you’re right about the Alltracs, all years had the big ones :thumbsup:
1990 Celica AllTrac
shadow_coupe
