CS 185 vent install on ST165 (pics)
Postby Rick89GTS » Thu Sep 02, 2004 11:46 pm
Finally getting down to business:
Rick89GTS
Postby Plex » Thu Sep 02, 2004 11:54 pm
Lookin good... do mine next.
..:.Red 1988 ST165 All-Trac Turbo.:..
Plex
Postby saved_1992 » Fri Sep 03, 2004 12:53 am
looks good, where did you source the vent?
was this in the planning for when you do the 205wta?
mike
omaha,ne
1988 a driver (RED) sold
1992 the keeper (RED)
1993 sold to 2of81 (RED)
saved_1992
Postby Rick89GTS » Fri Sep 03, 2004 1:20 am
saved_1992 wrote:looks good, where did you source the vent?
Got the vent from another AllTrac owner (who was lucky enough to have a spare! :shock: ) I've been wanting to install the vent for a long time simpy b/c of the crazy underhood heat that these cars generate.
The 185CS/RC or 205 WTA IC is another thing for the future that goes on the wish/to do list :wink: Still have to get my TT hooked up and I'm looking to put in some extra gauges somewhere too.
Rick89GTS
Postby Kyoto » Fri Sep 03, 2004 2:44 am
Good stuff Rick! Those vents look awesome on 165s. I'm going to do mine in a few months me thinks, but i need to get another hood so i don't butcher the original one too.
Tim // Melbourne, Australia
1986 ST165. 152,000km on chassis
ST205 WRC engine / IC system / rear LSD with 82,000km
Blitz K1-380V
Apexi Power FC
Aussie 3" dump pipe to 3" catback system
TWM short shifter.
Whiteline front strut brace
Kyoto
Postby Shaggz00 » Fri Sep 03, 2004 3:06 am
Kyoto,
Are OEM CS vents common on your part of the alltrac world? I really want one!
-Avi-
Shaggz00
Postby AWDtoyota » Fri Sep 03, 2004 6:22 pm
That looks great! :D
Can you take some pictures of the hood on the car. Jus curious as to how it looks, and where the scoop falls.
Some questions
What did you use to cut the hood? Does the scoop fit flat against the hood, all the way around? Any plans for keeping water out. Last one...for now. Did the bottom of the scoop touch the under-hood ribbing.
-Thanks
Ft. Laud., FL
'88 ST165
'84 Celica GT-S
AWDtoyota
Postby Rick89GTS » Sat Sep 04, 2004 12:59 am
AWDtoyota wrote:....Can you take some pictures of the hood on the car. Just curious as to how it looks, and where the scoop falls.
Some questions
What did you use to cut the hood? Does the scoop fit flat against the hood, all the way around? Any plans for keeping water out. Last one...for now. Did the bottom of the scoop touch the under-hood ribbing.....
I'm still working on final fitment; the pics show a test-fit only.
- I used a Dremel tool for tight corners and a grinder with cut-off wheel for straighter cuts.
- I'm still working on the fitment, so it doesn't fit completely flush at the moment.
- I'm gonna use EDPM material (thin rubber sheet) as a gasket to keep it from rattling and to seal it against the hood itself.
- the ribbing may still be removed to ensure proper fitment.
I'll probably have to put a support bracket in but I'll post up more pics as soon as I'm done, (hopefully soon!) :wink:
Rick89GTS
Postby 1stGenAllTrac » Sat Sep 04, 2004 2:48 pm
k that looks solid!
i wish i had one for my car,
i have a spare hood so i put a vent in one of them a couple weeks ago, i can post pics on a new thread later..
i just removed the bracing, traced a pattern, cut it out with a jigsaw and went over the edges with a dremel then put door edge trim around the opening. i still gotta put some screens underneith to finish it off, but it doesnt look TOO bad.. haha.
can't wait to see that hood on the car when u'r done!
1988 st-165 :: not stock....
1stGenAllTrac
Postby Guest » Sat Sep 04, 2004 11:38 pm
Plex wrote:Lookin good... do mine next.
:D
Guest
Postby Rick89GTS » Sat Sep 04, 2004 11:44 pm
1stGenAllTrac wrote:k that looks solid!
i just removed the bracing, traced a pattern, cut it out with a jigsaw and went over the edges with a dremel then put door edge trim around the opening. i still gotta put some screens underneath to finish it off, but it doesn't look TOO bad.. haha........
Looking forward to seeing your custom vent :D
Rick89GTS
Postby scandinavian link » Sun Sep 05, 2004 6:41 pm
we really need that stinking group buy for carbon fiber cs hoods.
much too hot in there...goodness...run the car 1 minute on a cold day and it's 600 degrees under there. :shrug:
anyway....looking good man :D
bryan -central ohio
2000 zzt231
1988 st165 (sold)
1990 st185 (brother's)
scandinavian link
Postby Guest » Mon Sep 06, 2004 12:34 am
Shaggz00: Nah, not really. Im from Melbourne and one went on eBay recently for $120AUD but i found out about it just after the auction :(
As for OEM models, does anyone know if they are even available new? I only planned to use the Eribuni one and mold it into the hood using body filler or something. Nothing too fancy really...
If anyone can get a group buy happening i am definitely in but i don't expect anyone to do it.
Guest
Postby st165 » Mon Oct 11, 2004 4:58 am
hey guys i have a cs vent sitting in my garage right now, if anyone is interested in it just email me at mazdaspeedprobe1@netscape.net
st165
Postby Rick89GTS » Mon Oct 11, 2004 5:37 am
Is it OEM factory or aftermarket Erebuni or something else? Price?
Rick89GTS
