A
Anonymous
Guest
any one know how to create the 'sleepy eyes' effect with the headlights?
Or do it the easy way:liljae8":epoj3c86 said:yah theres knobs under ur car that might be covered by rubber things. all you have to do is turn those and the headlights will go up. keep turnin to your desired position.
alltrac1993":308iefr4 said:just get that head light adjuster PIVOT makes. i got one and i love it. clean install to.
Fraggle":38pmclmt said:alltrac1993":38pmclmt said:just get that head light adjuster PIVOT makes. i got one and i love it. clean install to.
what is this headlight adjuster you speak of????
Meurz":3g67kycf said:Or do it the easy way:
Turn your lights on, highest point on the lever.
Turn them off, lowest point on the lever.
While going down, click 1 position up, needs some exercise, works very well.
In this case you cannot turn them on and let them stay halfway though.
alltrac1993":3ga256vf said:not only is for fashion, its also a performance mod. scoops up the air into the motor bay.
