Thought I would post this here
Pacific Northwest Areas
Postby ++ Sean ++ » Sat Oct 04, 2008 9:51 pm
262,000 Miles. Whats wrong? Leaks 1 quart of oil inbetween oil changes (cam seal), and the intercooler is dented and leaks.
1990 Toyota Celica GTS
* H&R Wheel Spacers 25mm
* ADR 17 Inch 5 Spoke
* 235-40-17 BFGoodrich G Force KDW
* OEM Altrac Hood
* JDM GT4 Corners
* Clear Bumper Lights
* JDM Vented Taillight Lenses
* Debadged
* 30% Tint
* Factory Blue Paint
* RC Bumper
* PIAA 1200 Driving Lights
* 1993 Celica JDM Tail Lights
* Kennwood DDX 7094 6.5 inch Touch Screen DVD Player, MP3
* Optima Yellow Top Dual Function
* Diamond Audio Hexes 6.5inch
* Diamond Audio Hexes 5.25
* Escort Solo S2 Radar Detector
* Rockford Fosgate Power 800.4
* Rockford Fosgate Power 800.2
* Rockford Fosgate Amp Link
* Stinger 0 guage
* Stinger 1.0 Farad Capacitor
* Infinity Perfect 12.1d x 2
* Custom Fiberglass Box
* Custom Wood Facades
* No Rear Seats
* HKS Type 1 Turbo Timer
* Lotek 3 way Gauge Pod
* Autometer 30psi Boost guage
* Autometer Oil Pressure Gauge
* Autometer Coolant Gauge
* JDM GT4 Steering Wheel
* TWM Short Shifter
* JDM GT4 Shift Knob
* Python Alarm
* Redline European Genuine Shift Boot
* 160 Amp Startech.com Alternator
* Eibach Prokit Springs
* Koni Sport Struts Adjustable
* Adrian's Converted Rear Struts
* Two's R Us Uprated Swaybar EndLinks
* New Tie Rods, Ball joints
* Rear Chassis Strut Bar from ACE Engineering
* Suspension Tech Rear Sway Bar
* Whiteline Camber Bolts
* 1993 2.0 3SGTE JDM
* HKS SSQV BOV
* Aquamist Water Injection .7mm Orifice
* Custom 3inch Down Pipe
* Custom 3 inch Exhaust W/ Magnaflow Muffler
* Custom 3 inch Aluminum Intake
* Aluminum Catch Can
* Walbro 255 lph Fuel Pump
* Daily Driven @ 14psi
* 32x12x3 Front Mounted Intercooler
* 2.5 Inch Piping, T-Bolt Clamps
* ATS Throttle Body Inlet
* Blitz SBC-ID Electronic Boost Controller
* Blitz Power ID Meter
* Speed Source Aluminum Crossmember Bushings
* Speed Source Poly Mounts
* Two's R US Valve Cover Bolts
* Garrett T3/TO4E 54 Trim Turbo
* Tial 38mm Wastegate
* Lovefab.com Exhaust Manifold
* Fidanza Lightweight Flywheel
* Spec Stage IV Clutch
* 1993 RC Alltrac Gearbox with Cusco 1.5way LSD
* Mr2 Internal Gear Box triple Spray Pipes
* Speed Sourch Cable Bushings
* Speed Source Stainless Braided Clutch Line
* Speed Source Crossmember Bushings
* Speed Source Extended Slave Cylinder Rod
20+ thousand invested, selling for 5,000 OBO. I will just part it out if it doesnt sell.
509 998 2067
SeanGTS2@gmail.com
5,000 OBO Will part out in less then a month.
[img]http://www.celicatech.com/gallery/files/1/2/P1000595WinCE.JPG[/img]
Turbo 1990 Celica GTS T3/T4 57 trim
2005 Infiniti G35 Coupe 6MT Sport
2007 Kawasaki Ninja ZX-10R
1999 Toyota Camry
2007 TRD DBL Cab Tundra 5.7L
++ Sean ++
Postby EasternBandit » Sun Oct 05, 2008 6:42 am
Sorry to hear that you're selling it. Dibs on the aquamist though. Or you know you could just sell me the aquamist and sell the car whole without it :P
If you do part it though I'd probably grab the catch can and maybe even the tires... if they have good tread left. Love my KDW's and wouldn't mind a replacement set sitting aside.
Also local pickup :D
chaos_cascade wrote:
Heh, you should prolly change your siggy Putting best foot forward and all.
May I suggest-
Black '93 ST185 - 1 of 81, CS Hood, CS Front, essence of cool
EasternBandit
Postby 3s_woob » Sun Oct 05, 2008 7:41 pm
Wow Sean! I remember when i first met you at your house when i bought those parts off your clip. what are your plans after selling it? Well good luck with your sale of one clean car!
Ryan
'91 ST-185 RC Conv.
'88 AW11 SC
Seattle, Wa.
3s_woob
Re: Thought I would post this here
Postby 93cc » Thu Oct 09, 2008 5:22 am
bummer that you are selling your car... What do you plan on buying next?
If you end up parting it might be interested in...
93 Black AllTrac
13 Scion FRS - Current Daily Driver
81 Black/Blue Celica - Sold
2007 Silver Tacoma Sport
93cc
Postby AWDios » Thu Oct 09, 2008 3:52 pm
Share on PSTOC too. might get a buyer there. Sorry to see it go though.
www.pstoc.org
Formerly known as GT-Four195
AWDios
Postby Terracar » Wed Oct 15, 2008 1:18 pm
Hate to see it go, but if you part it outI am interested in the following:
Rear strut brace (wasn't listed, but in pics)
CS Bumper
Turbo Timer
Lotek A-pillar pod
flywheel (assuming 3sgte)
-Terracar
Terracar
Postby turbo4wd » Wed Oct 15, 2008 1:30 pm
damn... if you were closer to TN.. I'd snap this up..
good luck with the sale!
Dan
Undercover Moderator
turbo4wd
Return to NorthWest
