I was trying to look for a thread here on it (I know there is one). Anyways, the fronts are easy - they just go in. The rears will need to be converted to inserts. It will require some threading and fabrication. If you're not too much of a DIY person or just lack the tools, there should be a shop around your area that will do it. I Did you already have a specific brand/model you're looking to put in? Some brands to think about - Whiteline (Koni's), KYB AGX's, KYB GR2's. For the AGX's, you will get MR2 turbo rear struts which apparently will fit well and handle our weight.
