I need some help
Moderator: lumbercis
Postby alltracman78 » Sun Jan 02, 2005 3:05 am
Good to hear! :)
Postby illGT4 » Sun Jan 02, 2005 4:48 am
Great to hear!
My poor cold idle has to do with the damn IAC valve also.
And I also need a midpipe, but only because I'm sick of the stock exhaust on this 165. lol.. need better exhaust so I can add this MBC i've got laying here.
Imagewww.illtuned.com
- Vehicle Dynamics Specialist
illGT4
Postby RossW » Sun Jan 02, 2005 11:25 pm
If you do get a new midpipe, let me know because I'll buy your stock one...
»Ross Wendell
»MIT Class of 2009
»1988 Toyota Celica AllTrac
»1987 Toyota MR2 Turbo
RossW
Postby RIalltrac » Mon Jan 03, 2005 12:34 am
okay I have to ask, but what is an IAC valve. I have just about all the abbreviations down, but I cant think of what this one is. My cool idle sucks lately, and I'd love to track down the culprit.
Chris - 90 ST185
RIalltrac
Images: 2
Postby RossW » Mon Jan 03, 2005 12:39 am
Idle Air Control Valve. It's the little bastard under the throttle body that's supposed to regulate air flow at idle.
»Ross Wendell
»MIT Class of 2009
RossW
Postby alltracman78 » Mon Jan 03, 2005 12:40 am
Probably that or your cold start sensor. Or bad connections.
Postby RIalltrac » Mon Jan 03, 2005 12:33 pm
is that the little bastard with the black plastic screw in it? The screw has a spring behind it? If so mine isnt under the TB, its more off to the side on the drivers side of the car. I've tried adjusting it, but it doesnt do squat
Chris - 90 ST185
RIalltrac
Images: 2
Postby illGT4 » Mon Jan 03, 2005 5:29 pm
IAC is under tb on 2nd gen.
directly under
illGT4
Postby alltracman78 » Mon Jan 03, 2005 10:19 pm
Chris, what your describing sounds like the idle adjustment for the ac.
Postby illGT4 » Mon Jan 03, 2005 11:00 pm
alltracman78 wrote:Chris, what your describing sounds like the idle adjustment for the ac.
No. The ISC valve. It's attached to the throttle body.
Not the A/C idle up.
illGT4
Postby alltracman78 » Tue Jan 04, 2005 12:27 am
RIalltrac wrote:is that the little bastard with the black plastic screw in it? The screw has a spring behind it? If so mine isnt under the TB, its more off to the side on the drivers side of the car. I've tried adjusting it, but it doesnt do squat
This.......
sounds like ac idle up.
Postby Mafix » Tue Jan 04, 2005 3:17 am
you should be able to blast air through the coolant lines on the IAC and that should clear up any problems with it. careful with pressure.
Postby alltracman78 » Tue Jan 04, 2005 3:18 am
Mafix wrote:the coolant lines on the IAC
Postby illGT4 » Tue Jan 04, 2005 4:16 am
there are coolant lines running to the ISC valve.
I'm not sure if or how running pressure through the lines will fix the ISC valve if it's faulty. Bang on it, or get a new one.
Peace.
illGT4
Postby Mafix » Tue Jan 04, 2005 11:32 pm
if the car sits a lot or has cruddy coolant in it or has some debris floating in the coolant 9 out of 10 that's where it'll clog. that's why you blast it out.
Return to NorthEast
