moving to mass.
Moderator: lumbercis
moving to mass.
Postby RafaCalde » Thu Jul 08, 2010 3:50 am
hey guys, i'm gonna be moving to boston within a month and a half. i need to know if i need to do anything to make sure my car passes inspection. right now i have a Berk Tech dp and straight 3 inch, no cats since i've been in florida for 5 years. anyone think i could pass inspection? everything is stock, sorta. it's an rc motor and ecu but it's all stock. everything. also what else is looked at during the inspection. any and all help please, i don't and won't have another car for a while.
Rafa
RafaCalde
Re: moving to mass.
Postby alltracst185 » Thu Jul 08, 2010 9:36 pm
Well since it's a 1990 you will not get smog tested(OBD2 only, 95 and up), cats and muffler are only visual. It just needs to pass safety pretty much! :D
alltracst185
Re: moving to mass.
Postby RafaCalde » Fri Jul 09, 2010 12:15 pm
ok thats good for me then. what does the safety test consist of? i'm just trying to make the transition as smooth as possible.
Rafa
RafaCalde
Re: moving to mass.
Postby WarTowels » Fri Jul 09, 2010 1:59 pm
I'm not from Mass, but I'd like to extend an apology in advance on behalf of all of the idiots your going to meet on the road.
I hope you like dents. :evil:
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Re: moving to mass.
Postby alltracst185 » Fri Jul 09, 2010 9:47 pm
RafaCalde wrote:ok thats good for me then. what does the safety test consist of? i'm just trying to make the transition as smooth as possible.
Like horn, blinkers, lights, e-brake, tires, tire rod ends, struts, rust holes ect.
alltracst185
Re: moving to mass.
Postby RafaCalde » Sat Jul 10, 2010 10:10 am
towels, i'm not too worried about it but thanks. i know the drivers there can be assbags. i've driven in boston and new york city so i know what to expect but thanks for the advice.
as for the other things. i'm gonna have to get my horn working again. i'm have to replace the strut tops cause they're not in the best shape. i gotta get some winter tires so i'm gonna wait til then to get my car inspected,. no rust holes, and tie rod ends are in really good shape. alright. thanks uys. anyone else have something to add?
Rafa
RafaCalde
Re: moving to mass.
Postby RafaCalde » Sun Jul 11, 2010 6:41 am
my next question is where is the closest 1/4 mile dragway locaeted.
Rafa
RafaCalde
Re: moving to mass.
Postby alltracst185 » Sun Jul 11, 2010 1:06 pm
New England Dragway in Epping NH. About 2 hour drive from you. :D
alltracst185
Re: moving to mass.
Postby pipes » Sun Jul 11, 2010 3:35 pm
hit me up when u arrive i have a 95 gtfour
i built it but i dont know why
pipes
Re: moving to mass.
Postby alltracst185 » Sun Jul 11, 2010 8:49 pm
I'm also only about a 30 miute drive away! I have a 90 and a 88 trac.
alltracst185
Re: moving to mass.
Postby WarTowels » Mon Jul 12, 2010 5:23 pm
95 gtfour??? I want to see!
I'll be down in Boston in maybe 2-3 weeks...
-Greg
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Re: moving to mass.
Postby alltracst185 » Tue Jul 13, 2010 1:33 pm
If i can get my st165 wire harness rewired in this time we should put together a mini meet :shrug:
alltracst185
Re: moving to mass.
Postby WarTowels » Tue Jul 13, 2010 9:51 pm
Agree.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Re: moving to mass.
Postby RafaCalde » Mon Jul 19, 2010 2:08 am
ill be in touch with you guys when i get up there. i have a lot of things to take care of to make this happen. i might need delay it a little bit. my company doesn't have the openings i'm looking for and i'm obviously not gonna move without a job. i'm excited though. i'm coming back to my first home.
Rafa
RafaCalde
Re: moving to mass.
Postby GMan » Tue Jul 20, 2010 8:34 pm
I hope you can make it up. '97 and newer has to pass OBDII, other than that no emission inspection.
Just have to pass safety.
So you are Home free in that regard.
Not much car action up here though. :shrug:
Regards;
GMan
Return to NorthEast
