moving to mass.
Moderator: lumbercis
Re: moving to mass.
Postby WarTowels » Thu Mar 22, 2012 12:05 am
I'd probably be down to meet up with you guys, June 2nd is a Saturday.
I might be in a MR2 turbo or a S2000, but certainly no All-trac.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Re: moving to mass.
Postby RafaCalde » Thu Mar 22, 2012 5:19 am
Absolutely guys. Won't be driving my trac either. But I am definitely down for meeting up. Get a nice group together and find something to do in the Boston area. Maybe Epping Raceway? Been a while since I've seen some good track drag racing.
Rafa
RafaCalde
Re: moving to mass.
Postby alltracst185 » Sat Mar 24, 2012 1:08 pm
i find it funny that we all have All-tracs but no one will be driving them to meet up :( I'm down to meet up any time, I will also not be in the trac (depending on when we meet up :wink: ) She should be done but not tuned till mid summer, I'll be in my DD TSX. Lets deff get a meet going :D
alltracst185
Re: moving to mass.
Postby RafaCalde » Sun Mar 25, 2012 4:53 am
I ask myself if there will ever be a day that we could have a meet with the alltracs.
Rafa
RafaCalde
Re: moving to mass.
Postby alltracst185 » Sun Mar 25, 2012 11:30 am
RafaCalde wrote:I ask myself if there will ever be a day that we could have a meet with the alltracs.
Whats going on with your Whit beast of the northeast? Mine will be done sometime this Spring, Dyno ready in a minth or so :D
alltracst185
Re: moving to mass.
Postby tommy8768 » Sun Mar 25, 2012 12:26 pm
I live about an hour away...and I was a Toyota mechanic for years. Hit me up if you need help.
tommy8768
Re: moving to mass.
Postby RafaCalde » Sun Mar 25, 2012 1:55 pm
It's short list, mainly things that won't let it pass inspection(damn Massachusetts laws). Windshield needs to be replaced, brakes need to be redone, and I need a brand new suspension. These roads in Boston would any kind of stock suspension and I don't want to rebuild it. I'm gonna start saving up for a coilover kit. Other than that, she runs pretty well, just a few bugs in the system. Does anybody have a complete list of what the inspection looks for?
What kind of numbers are you looking at when all said and done? I'd like to watch the Dyno session.
Rafa
RafaCalde
Re: moving to mass.
Postby alltracman78 » Sun Mar 25, 2012 10:46 pm
We used to have meets a couple times a year. We did the CSP meet every spring and fall, and we'd meet up when I came up from NC sometimes.
People stopped showing up. :shrug:
Rafa, more things will pass inspection than you'd think. You'll have to fix the windshield [most insurance will fix it for free], but as long as your lights tires [they usually check tire wear for evidence of worn suspension] wipers and horn are good you're USUALLY ok. Oh, and no warning lights on.
And if you do fail you have 30 days to get whatever they fail you on to pass.
Depending what happens I may show up [I'm supposed to work that day].
Re: moving to mass.
Postby RafaCalde » Mon Mar 26, 2012 4:32 am
Well, my horn doesn't work and my suspension needs replacing. The warning light I have is the check engine light because of the RC/CS intercooler water level sensor isn't pinned as I do not have the intercooler installed s there anyway to bypass it?. And my ABS light is on cause one of the sensors is broken at the hub. I think my oil pressure sender went to crap too cause I've left car idling for an hour and I've lost no oil whatsoever since the last change last June. I'm in no rush to fix any of this stuff so I'm just taking it real slow.
Rafa
RafaCalde
Re: moving to mass.
Postby alltracman78 » Mon Mar 26, 2012 10:55 am
It's hard to fail for suspension. Not impossible, but hard [aside from worn ball joints/bushings].
Horn should be relatively easy to fix, it's a simple circuit with everything easily accesible. The hardest thing is getting at the button under the airbag.
The level sensor is easy to bypass, you just need a pin from an ECU connector with about 4" of wire; attach a spade or ring terminal to it and ground it to the ECU mounting stud. I don't remember which pin it goes in right now [I'm running an ST205 ECU] but it is much easier than pulling apart the dash. And this way your MIL still works if there's another problem.
ABS will be a pain. The sensors are almost never easy. And an ABS light will probably fail you.
Your oil pressure sender doesn't matter [as far as inspection]. And is easy to fix. :)
Re: moving to mass.
Postby RafaCalde » Mon Mar 26, 2012 12:11 pm
Ok, doesn't sound too too bad. Balljoints could be replaced, was planning on doing that anyway. The bushing up front are less than two years old and they're the Superpro poly. The rears I'll have to examine. The problem with the horn is that I had to remove the relay cause one day out of frustration I hit the steering wheel and the horn went off and didn't stop.
Rafa
RafaCalde
Re: moving to mass.
Postby dustinbart » Mon Mar 26, 2012 4:08 pm
Hey where are you in mass? I know a few shops ive passed both my alltracs at no prob. Also im down for a meet and I Will be bringing one of my alltracs if it goes down. Im in boston quite often because my gf lives in brookline, ley me know i'll certainly be down tp meet some fellow alltrac family. Oh if you ever see a blue alltrac st165 around wave because im sure its me. Oh id only be able to meet on a saturday night or sunday.
88' st165-Gun metal (The build)
88' st165-Blue (DD)
86' Landcruiser FJ-60- Satin black (The Monster)
dustinbart
Re: moving to mass.
Postby alltracst185 » Mon Mar 26, 2012 10:20 pm
It sounds like this might end up being a decent turnout :D
I'm Looking to make about 500+ AWHP :evil:
alltracst185
Re: moving to mass.
Postby RafaCalde » Mon Mar 26, 2012 11:26 pm
Wow, impressive. I'd like to hit 400-450 AWHP when I'm done with mine. I live in Jamaica Plain, 10 mins from Brookline by car and 15 mins outside Downtown by subway.
And I agree on the turnout. So when do we want to do this? Me personally, I'd like for the warm weather to make a permanent stay first. I'd say maybe around the end of May? What does everyone else think?
Rafa
RafaCalde
Re: moving to mass.
Postby dustinbart » Mon Mar 26, 2012 11:52 pm
I'd also like to wait for some warmer weather. I'll be getting new tires in the next cpl weeks so i should be good to go. Im also building my other st165 for a cool 400 awhp so i can still have some fun on.the road withoit breaking something and being down every other day. So id really like to hear what you guys are doing in hopes of getting those numbers. We should choose a date in advance so everyone can fit it into their schedule. But someone else has to drive their alltrac too i cant be.the only one.
88' st165-Blue (DD)
dustinbart
Return to NorthEast
