88gt4DE":1rxs8na1 said:celi_wabbit : slam a little toyota sealer on that pinhole ... you said near cap ? so its on the plastic part im guessing ... :shoots:
Dan : Mike ( 97jza80 ) just bought an alum radiator too ... we will see how his works out ... US seller though unlike mine ... and better price 8)
As for the radiator, you might have to suck it up and either get a new one, add some stop leak, or drain it and apply some apoxy. If you are talking about the toyota sealer (F.I.P.G), then I would not recommend it because to seal the radiator you need something that can handle pressure; after all the radiator keeps things cool because it keeps the system under pressure. Toyota sealer, would simply act as a balloon and blow up when pressure builds. One more option would be if you can reach the hole from the mouth of the radiator, would be to drain it a bit, and then use jb weld for plastic and set it up from the inside; that way the more the pressure builds, the tighter the seal will get.
