Anyone have a working stock head unit...
Moderator: lumbercis
Postby lumbercis » Mon May 09, 2011 3:59 pm
...for a 92 with system 10 that they can let go for a reasonable price?
Have a long road trip planned and would like to have some tunes on the way.
Leaving in a week and half, so let me know soon if you have one you can part with..
Thanks!
J.
Caldina powered...
lumbercis
Re: Anyone have a working stock head unit...
Postby Awesome-Trac » Mon May 09, 2011 7:02 pm
you know you can always go to the junk yard and use any toyota system...using a 90 corolla right now :wink:
•Daniel
Awesome-Trac
Postby lumbercis » Mon May 09, 2011 8:33 pm
I thought our systems used an unusual plug configuration on the back of the head unit?
http://www.mr2oc.com/showthread.php?t=240774
It looks like System 10 uses the 15-pin externally amplified connector?
J.
Caldina powered...
lumbercis
Postby Awesome-Trac » Mon May 09, 2011 8:46 pm
nope...if you have the same OEM wire harness for the stereo most oem toyota radios are compatible with eachother depending on the year your getteing it from.
drove for 2 months using a battery operated radio until i found out i can use the corolla radio that was just sitting at work :bangshead:
•Daniel
Awesome-Trac
Postby lumbercis » Mon May 09, 2011 11:52 pm
What year corolla was the head unit you using out of?
J.
Caldina powered...
lumbercis
Postby 88gt4DE » Tue May 10, 2011 12:04 am
Some scion ones work too , I have 3 new ones out of new scions that had radio upgrades .... one is a t1807 , other two are t1808's one with a missing knob and one with both knobs but on has a little scuff on it .... all work perfect :) If you ebay those codes it will show you what they look like 8) However they are double din radios so you would lose a pocket under radio if you have one ...
Postby lumbercis » Tue May 10, 2011 12:12 am
http://shop.ebay.com/i.html?_from=R40&_ ... Categories
http://cgi.ebay.com/ebaymotors/Pioneer- ... ioQ5fVideo
This one shows the pins on the back of the unit.. looks like standard 10-pin/6-pin? :shrug:
J.
Caldina powered...
lumbercis
Postby 88gt4DE » Tue May 10, 2011 12:19 am
Does the System 10 have some wierd plug ? If so I've nver seen it ... I have a really old toyota head unit out of god knows what and it only has 1 plug and 15 pins ... anything like that ?
Postby CMS-GT4 » Tue May 10, 2011 1:22 am
What kind of features does the scion radios have? MP3 input?
Postby 88gt4DE » Tue May 10, 2011 1:31 am
CMS-GT4 wrote:What kind of features does the scion radios have? MP3 input?
No aux jack if thats what ya mean , toyota puts those in the console and in other places ... these is a available ipod cable that plugs into the back of it ... I dont have any of those though.
Postby Awesome-Trac » Tue May 10, 2011 3:25 am
i used a 1990 corolla radio
•Daniel
Awesome-Trac
Postby CMS-GT4 » Tue May 10, 2011 12:44 pm
That is perfect. I just want an iPod hookup. I may ditch my alpine cassette player if these fit well in the Ken dash and can run thru the whole system 10.
Postby lumbercis » Tue May 10, 2011 1:21 pm
I'm virtually certain the Scion radios don't work unless there are specific ones with a 15-pin plug or else you make a patch harness...
The stock system-10 uses a 15-pin plug which is a bit unusual except in early-late 90's toyotas. The "standard" plug is the 10-pin/6-pin... at least that's what I've been able to gather from my research.
J.
Caldina powered...
lumbercis
Postby CMS-GT4 » Tue May 10, 2011 2:51 pm
Well if anyone gets one working in a 185 please let us know, cause this would be my optimal setup. I do not like to give anyone a reason to break into my cars, so I keep my audio low key.
Postby BoostedBlueToyotas » Wed May 11, 2011 12:25 am
The Scion radios have internal amplifiers. The system 10 wiring setup basically has a seperate harness that runs from the amp with one connector that plugs into fusebox in passenger side kick panel (probably for the subwoofer in the door) and then a harness that runs to the radio. This end has 2 connectors, one is the 15 pin that goes into system 10 radio and one is a connector that plugs into the connector that would plug into non-system 10 radios. Remove this connector to the system 10 harness and you probably could plug it into an amplified scion radio just like you would plug it into a stock (non system 10) celica radio from the day. In either case you will loose the door speakers.
Tim Plessing
Columbia, MD
BoostedBlueToyotas
Return to NorthEast
