Cracked Block :-(
Moderator: lumbercis
Cracked Block :-(
Postby gt4play » Thu May 10, 2012 4:04 pm
So, keeping a long story short, I determined this past weekend that I have a crack in my 93 block. I've been wrestling with a steady coolant leak for longer than I can remember. I always thought "eh, it's the 'other' hose from hell just below the water pump...I'll get to it". Well, I finally got around to replacing it - only to see I still had a leak from the same general vicinity. Awesome.
Ultimately, I was really hoping for a popped freeze plug, but turns out there's a fracture in the outer portion of the block, just above the freeze plug that sits right behind the water pump. It's a vertical crack that runs right into the freeze plug cavity. WTF!
I've never run this car hard, always had coolant in it, etc. Granted, there was a period where it sat for a long period of time..but can't imagine 'sitting' would result in something like this.
I'm told these things can be repaired (only after everything is pulled and the block is stripped bare). But I'm wondering if I should just go with a replacement.
I do NOT want to sink a ton of money into this. An investment in time is okay - I have the space in the garage to casually work on it. Just kinda bummed - I was looking forward to having her out this summer. :-/
-C
gt4play
1988 ST165 [<23k miles]
1993 ST185 [my baby]
1994 MR2T, gen3 w/all the upgrades [cracked the block, rebuild in progress]
2006 Mini Cooper S [commuter]
2001 Tundra Ext Cab, V8 [work horse]
2010 Highlander Limited [family vehicle]
gt4play
Re: Cracked Block :-(
Postby Mafix » Thu May 10, 2012 4:26 pm
i'd just find a stock replacement block. can't be that hard to do?
Postby saved_1992 » Thu May 10, 2012 4:32 pm
have you tried any stop leak stuff? BG stop leak iv had really good luck with (usually a dealer item)
mike
omaha,ne
1988 a driver (RED) sold
1992 the keeper (RED)
1993 sold to 2of81 (RED)
saved_1992
Postby celi_wabbit » Thu May 10, 2012 4:36 pm
I maybe parting out my RC motor. I just pulled it out bc I had a bad valve tap and replaced it with the ST215 4th gen. So, I am looking to part out my RC motor (pick up only) in Pennsylvania.
1993 MR2 N/A - Sold
1995 Tacoma - Sold
1991 Celica Alltrac - Sold
1994 Celica GT - Project
2010 Mercedes-Benz
celi_wabbit
Postby gt4play » Thu May 10, 2012 4:42 pm
saved_1992 wrote:have you tried any stop leak stuff? BG stop leak iv had really good luck with (usually a dealer item)
I've never gotten a warm n fuzzy about this stuff. It's an additive, right? I'm concerned what it might do to a radiator...
gt4play
gt4play
Postby gt4play » Thu May 10, 2012 4:45 pm
Mafix wrote:i'd just find a stock replacement block. can't be that hard to do?
Well, true. But there's two things that concern me. (1) I have to know it's coming from somebody reputable that I can trust. I don't want to get a block from somebody only to find out after inspection that it's out of spec for a stock setup. (2) I kinda wanted to keep the numbers matching on this car.
gt4play
gt4play
Postby Insanity-74 » Thu May 10, 2012 4:47 pm
Last time I used that stuff it blocked the radiator and the turbo water feed killing both (Not on a Celica though)....its horrible stuff that should be avoided at all costs.
Insanity-74
Postby gt4play » Thu May 10, 2012 4:49 pm
celi_wabbit wrote:I maybe parting out my RC motor. I just pulled it out bc I had a bad valve tap and replaced it with the ST215 4th gen. So, I am looking to part out my RC motor (pick up only) in Pennsylvania.
I appreciate the consideration. And although enticing, this will start getting into something I'm trying to avoid - high cost. I'm not sure what you're looking to get for the setup, but I'm quite positive it's well out of the range I was looking to spend (particularly when I'm content with keeping this car, for the most part, stock).
gt4play
gt4play
Postby WarTowels » Thu May 10, 2012 4:54 pm
I could have sworn that one of the suppliers like KO or ATS had a new stock 3S block listed for sale in the ball park of $600 but now I can't find it anywhere...
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby gt4play » Thu May 10, 2012 5:03 pm
WarTowels wrote:I could have sworn that one of the suppliers like KO or ATS had a new stock 3S block listed for sale in the ball park of $600 but now I can't find it anywhere...
-Towels
Now that's what I like to hear (well, if it exists). PLEASE let me know if you find it. :-)
gt4play
gt4play
Postby Mafix » Thu May 10, 2012 6:37 pm
never never never use this stuff.
Postby Mafix » Thu May 10, 2012 6:38 pm
well about this part....you are screwed. you need a block. plain and simple. unless the plate is rivited on then it won't match. not that anyone will really care if you ever decide to sell. i know what you are getting at but at this point it isn't feasable.
Postby saved_1992 » Thu May 10, 2012 6:43 pm
why all the hate for the mechanic in the can :wink: , the BG product does not clogg it will actually flush out if one does a coolant flush. ive even went to the BG training school that was really exciting :shock:
i do have this in my celica, use it every time i change out the coolant. i also use BG other products too.
Part No. CT4
BG Universal Cooling System Sealer
BG Universal Cooling System Sealer is composed of refined organic fibers, rust and corrosion inhibitors, a buffering agent and anti-foaming ingredients. It stops head gasket seepage and seals small leaks in the radiator and heater cores. The rust and scale inhibitors help provide better heat transfer properties. It is compatible with all types of coolants and harmless to all metal or rubber parts.
Part No. 511
Part No. 5118 12 oz. (355 mL) bottle
8 oz. (237 mL) bottle
GO BG :lol:
mike
omaha,ne
saved_1992
Postby WarTowels » Thu May 10, 2012 9:59 pm
I looked for about 40 minutes! Couldn't find it... KO's site says they lost some content recently, I don't know if this could have been part of that... I suppose it's worth an email/call.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby UtahSleeper » Thu May 10, 2012 10:10 pm
That sucks.
I know this sounds ghetto, but just thinking. Maybe drain the cooling, clean and rough up the crack and JB weld it? Just thinking if it's not a high pressure area it might hold it for awhile.
UtahSleeper
Return to NorthEast
