Cracked Block :-(
Moderator: lumbercis
Re: Cracked Block :-(
Postby lumbercis » Fri May 11, 2012 3:24 pm
I'd just call ATS and ask. I'm SURE they'll sell you a stock rebuild. They probably just don't list it on their site since almost everyone is looking to upgrade. http://www.atsracing.net/
Caldina powered...
lumbercis
Postby alternate.eago » Fri May 11, 2012 6:42 pm
I thought you had a spare 3s in your garage from when you did the yellow deuce...
alternate.eago
Postby 2of81 » Fri May 11, 2012 7:52 pm
Caddilac stopleak pills work too, just dont use Bars shit, hell try coarse ground black pepper.
Justin
1972 Corolla TE27
2of81
Postby gt4play » Tue May 15, 2012 4:36 pm
posted pics in the original post....
gt4play
1988 ST165 [<23k miles]
1993 ST185 [my baby]
1993 Supra TT Hardtop [my other baby]
1994 MR2T [back together]
2001 Tundra Ext Cab, V8 [work horse]
2010 Highlander Limited [family vehicle]
gt4play
Postby gt4play » Tue May 15, 2012 4:44 pm
alternate.eago wrote:I thought you had a spare 3s in your garage from when you did the yellow deuce...
Well, technically yes - but I'm attempting to keep that one intact to keep with the MR2. I also don't know if any additional damage beyond the spun bearing(s) occurred in that one. Guess I should look further into it.
gt4play
gt4play
Postby alternate.eago » Tue May 15, 2012 6:52 pm
I thought you actually had a couple of them back there... :)
OT: Hows that minty st165 treating you?
alternate.eago
Postby gt4play » Mon Jun 04, 2012 7:03 pm
Well, I decided to actually have a go at the infamous JB Weld approach. I've read a number of success stories with this stuff - if I can get this to last me through the summer, all the better!
Oh, and btw, there's more than one crack in the vicinity. Despite my good intentions, it certainly appears I did a crap job at making sure my car had the proper coolant mixture when it sat for a while.. :(
Pulled basically everything I could in the front to minimize the amount of swearing and acrobatics to get the job done
You can see the one crack at the top of the freeze plug cavity - it extends further up about halfway to the mating surface. The other, longer crack is off to the left, kinda horizontal...you can see the dark line from moisture seeping through.
My attempt at tracing the crack and 'starter' holes to prevent the crack from spreading
A rough surface is recommended for proper adhesion. In addition to this, I went at this with 120grit sandpaper (not pictured). Rough enough?
JB Weld applied. I placed a thin piece of clear plastic over the freeze plug area to keep this stuff from oozing south. I'll go in there with the dremel and clean it up a bit so I can at least get that piece removed. Considering this entire area is pretty stress-free, I'm optimistic this approach will work, at least through the summer. Anybody wanna start placing bets? ;)
gt4play
gt4play
Postby Mafix » Thu Jun 07, 2012 1:38 pm
are we only betting on this summer? or until next summer.
this summer, 20 bucks says it holds.
next summer, 50 bucks says it leaks.
Postby WarTowels » Thu Jun 07, 2012 2:11 pm
Frightening! I think it would hold for a short time, but kinda scary either way. I love JB weld, but I don't have all that much trust in it.
Hope you find a new block soon, I never did end up finding where I thought I had seen them for sale - new.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby celicat93 » Thu Jun 07, 2012 2:26 pm
All-Trac's aren't Corvettes, they never will be, don't worry about matching numbers.
celicat93
Postby UtahSleeper » Thu Jun 07, 2012 3:52 pm
With how many alltracs have the motors swapped, I would think a matching alltrac would be the rarest of all cars lol.
I think it will hold and hope it lasts long enough for the motor to actually die from a standard bearing or piston failure, something worthy of replacing a block lol.
UtahSleeper
Postby gt4play » Thu Jun 14, 2012 7:08 pm
Well, so far the patched area is holding well - but only to see other leaks spring up from what appears to be behind the block. :-( I guess it's not much of a surprise if the original damage is truly attributed to freezing/expansion.
In a last ditch act of desperation, I added some of that Bars stop-leak. I know, I know...prob a bad idea. But at this point, I already knew the block was shot. My radiator is an aftermarket one that doesn't look long for this world. What's left? The head and heater core - the head can always be tanked. The heater core, well, will see if this stuff affects it much. I don't drive the car in the winter anyway - as soon as salt hits the road, the car stays indoors.
At any rate, I managed to get the car to the OC All Wheel Drive meet with a few other fellow members (literally hit the road 6 hours after I added this stuff). Despite the heat, the ol girl made it there no problems. It wasn't until I made it back to Annapolis that I ran into an overheating issue. About 1 gal of coolant had pushed out the reservoir overflow. Fortunately, it was a good stopping point for dinner anyway. And even more fortunate, after topping back off with coolant (a shout out to Eric and Willy for jumping in to help), the trac made it the rest of the way to Mt Airy without issue. :)
Not positive why I lost the coolant. Prob didn't help that I pressed my luck with my driving habits on the way back (no thanks to Willy and Eric... ;-) ). But all is well - she's safe n sound in the garage (still no leaks!). I'll likely limp along, keeping my drives local for the summer. In the meantime, I'll source a decent shortblock and have the machine shop go over it. Maybe I'll pull the head from the old MR2 GenII so I can have a full longblock on the stand before I start transferring components.
If anything, my baby is going to come out looking even cleaner than it already does. That engine bay is gonna be immaculate. :-)
gt4play
gt4play
Postby fussellbug » Thu Jun 14, 2012 10:02 pm
fussellbug
Images: 36
Postby gt4play » Tue Aug 21, 2012 3:22 pm
Well, after much discouragement between the two downed cars, I've finally mustered up the motivation I need to get things back on track. I sourced a full shortblock in VA for $100 over the weekend (head is still attached, seller will get it from me at a later time). It appears to be in great shape, but I'll probably still tear it down and have it tanked and inspected for good measure. It came out of a MR2 that received a Gen3 swap (engine was good before it was pulled).
Once I have a good base to work with, I'll just start transferring everything over piece by piece. Realistically, this probably won't be done until Spring. But I have the 165 to help ease the pain for a while. :D
Pless, if you're reading this, this will be a good time for me to see what you have left over for HPC coated goodies you may want to offload.
gt4play
gt4play
Postby bridge47 » Tue Aug 21, 2012 4:27 pm
Okay, some truth is needed in this thread.
-JB weld does not seal against pressure. Ever.
-JB weld is good for oil pans, etc where there is no pressure
When your block starts leaking again(and it will), find an old guy who has had experience welding small block chevy heads with high nickel content rod. This is a walk in the park for these guys.
Oh, and it's not 'freeze' plugs. It's core plugs. Don't count on cold temps to push them out. Not what they were designed for.
Facts are stubborn things.
bridge47
Return to NorthEast
