Cracked Block :-(
Moderator: lumbercis
Re: Cracked Block :-(
Postby gt4play » Tue Aug 21, 2012 5:13 pm
Some added clarification:
bridge47 wrote:-JB weld does not seal against pressure. Ever.
Although logic might dictate your statement to be 100% correct, there are proven instances where it actually has worked for others - for years on end. Regardless, my little JB Weld approach was not intended to act as a permanent solution, nor did I expect it would/could serve as such. It was indeed intended to be temporary just to get me through the summer (maybe a little longer if I was lucky).
bridge47 wrote:When your block starts leaking again(and it will),
It did - but not in the JB Weld patched area. The patch actually built pressure back into the coolant chambers, ultimately revealing even more fractures in the back of the block. I cannot say specifically where - at this point it didn't much matter to me anymore. I decided to take 'er off the road until I could ultimately source a replacement block, hence my latest post.
bridge47 wrote:Don't count on cold temps to push them out. Not what they were designed for.
Trust me, I wouldn't have deliberately disregarded the coolant mixture thinking these plugs (even if they were truly "freeze" plugs), would cover my butt in the event of freezing. Despite how positive I was that the mixture was proper, it apparently was not. Still kicking myself for this.
gt4play
1988 ST165 [<23k miles]
1993 ST185 [my baby]
1993 Supra TT Hardtop [my other baby]
1994 MR2T [back together]
2001 Tundra Ext Cab, V8 [work horse]
2010 Highlander Limited [family vehicle]
gt4play
Postby GT4_DRED » Tue Aug 21, 2012 7:48 pm
bridge47 wrote:When your block starts leaking again(and it will), find an old guy who has had experience welding small block chevy heads with high nickel content rod. This is a walk in the park for these guys.
X2..
'88 ST165 - project "Rahtid"
'91 MR2
GT4_DRED
Postby gt4play » Tue Aug 21, 2012 8:01 pm
X2..
Folks, I-bought-a-replacement-block.
After my new-found discoveries (mentioned already), there's no point in attempting anymore patchwork - regardless of how it's done.
gt4play
gt4play
Postby bridge47 » Thu Aug 23, 2012 3:14 pm
Wasn't trying to kick you while you're down.
Point of my reply was to help others in the same boat.
You did the right thing by getting another block. Even welding is hit or miss depending on who's doing the job.
Facts are stubborn things.
bridge47
Postby Mafix » Thu Aug 23, 2012 11:56 pm
just to chime in on the new subject:
i've seen several blocks/manifolds welded. i've never seen it hold. but that's just my experience.
i've seen several aluminum things welded, never seeen an issue from the repair.
the cast welding seems to be very very hard to do. even very experienced welders turn away from it. interesting...
Postby MWP » Fri Aug 24, 2012 12:27 am
After seeing the condition my block was in after having exactly the same crack, i very much doubt any type of repair (coolant additive, epoxy or brazing/welding) would hold for more than a few days.
The heat stresses in this corner of the block are huge!
When i finally pulled by block down (had been running it with the crack for ~4 months), the section that had cracked had a ~1mm lip on it. I was amazed it could deform that far.
Postby gt4play » Fri Aug 24, 2012 3:15 am
MWP wrote:After seeing the condition my block was in after having exactly the same crack, i very much doubt any type of repair (coolant additive, epoxy or brazing/welding) would hold for more than a few days.
That's interesting. It's literally the same exact crack! Do you think yours is attributed to freezing (at some point)?
gt4play
gt4play
Postby MWP » Sat Aug 25, 2012 10:52 am
Freezing... in Australia? :rofl:
Return to NorthEast
