Alternator rebuilds?
Moderator: lumbercis
Postby RafaCalde » Fri Jan 11, 2013 8:51 pm
Anyone know of a place that will rebuild alternators around Boston? I can't find a replacement and I'm trying to get the car running again. Or any Pull and Save, U-Pull It type places I maybe could find one.
Rafa
RafaCalde
Re: Alternator rebuilds?
Postby fussellbug » Fri Jan 11, 2013 10:41 pm
For many people, replacing the brushes in the alternator will fix their problems for the very low price of a set of carbon brushes.
fussellbug
Images: 36
Postby RafaCalde » Fri Jan 11, 2013 11:05 pm
where can i get a set?
Rafa
RafaCalde
Postby fussellbug » Fri Jan 11, 2013 11:29 pm
The EPC shows the brushes and holder as a set part# 27370-75060. Retail price of $19.75 at your local dealer or buy online.
fussellbug
Images: 36
Postby OutToWinPAHC » Fri Jan 11, 2013 11:42 pm
I got a shop near me in Philly. They have rebuilt my R33 alt, my R33 starter as well as countless other JDM stuff. Average rebuild cost for regulator, brushes and bearings is 50-80 bucks.
1990 ST185 All-Trac 54trim
1993 Nissan Skyline R33 GTS25T-M widebody built 60trim R34 NEO AEM-Series 2
OutToWinPAHC
Postby anothergt4 » Sat Jan 12, 2013 4:52 pm
Also mid 90s dodge intrepids used the same alternator if that helps, I just pulled the internals out of one and put them in mine, same denso part number, but my casing looked better so I just swaped internals.
anothergt4
Postby 88gt4DE » Sat Jan 12, 2013 9:03 pm
anothergt4 wrote:Also mid 90s dodge intrepids used the same alternator if that helps, I just pulled the internals out of one and put them in mine, same denso part number, but my casing looked better so I just swaped internals.
Seriously ? Dodge ? I worked for dodge for years and never knew this ... then again ... I wasnt wrenching on them everyday either ...
Postby underscore » Sat Jan 12, 2013 9:14 pm
Huh, go figure.
Postby RafaCalde » Sun Jan 13, 2013 8:49 am
OutToWinPAHC wrote:I got a shop near me in Philly. They have rebuilt my R33 alt, my R33 starter as well as countless other JDM stuff. Average rebuild cost for regulator, brushes and bearings is 50-80 bucks.
got any contact information? i found a place in Connecticut but they were quoting me 130 for a rebuild. would this place also slight power increases. I'd like to go from 80 amps to 100 amps.
Rafa
RafaCalde
Postby OutToWinPAHC » Sun Jan 13, 2013 2:17 pm
Pryor Auto Electric
(215) 338-1582
7156 Torresdale Ave, Philadelphia, PA 19135
I live a mile away, so I could drop it off and pick it up if you wanted to use them
OutToWinPAHC
Postby sentraman » Mon Jan 14, 2013 9:43 pm
Is this confirmed? anyone know?
04' Forester XT
sentraman
Postby RafaCalde » Thu Jan 17, 2013 11:41 pm
on another note, anyone know where i can find a windshield for decent price?
Rafa
RafaCalde
Postby esracing » Sun Jan 20, 2013 2:20 pm
just get a new one from toyota they are still avlible
2008 tundra blue
1988 st165 white imsa gto
1969 camaro 502 bb 630 hp black
esracing
Postby RafaCalde » Mon Jan 21, 2013 3:35 am
those are rather expensive. if i could find something used for less would quick good.
Rafa
RafaCalde
Postby alltracman78 » Tue Jan 22, 2013 5:15 pm
You know you can use one from a 5SFE, right?
And most are auto, so they have a slightly higher max output.
01 And older auto Camrys should be perfect.
As far as the windshield, pick one up from a yard, any liftback, and possibly the coupes too are the same.
Return to NorthEast
