anyone near pittsburgh?
Moderator: lumbercis
Postby lexustech » Thu Jul 04, 2013 9:03 pm
I am located north of pittsburgh. I need help getting my all trac running. It was running after putting a jdm engine in and
it made a noise and shut off, now it cranks, sounds like a normal crank to me, not fast like the timing belt broke or anything, but it wont fire. help!
Re: anyone near pittsburgh?
Postby GT-Steezy » Fri Jul 05, 2013 2:41 am
There's a number of things it could be. Was anything else going on at the time? Based on your description it could be fuel not reaching the motor, worn plugs, distributor. Or empty fuel tank. I'm just going off of the troubleshooting section of my book.
There's a few other things it could be as well.
Postby 88gt4DE » Fri Jul 05, 2013 7:40 pm
Gotta see if yer missing fuel or spark first and then we can help ya man ! My 165 came from " Smithton " Just south of you ...
1988 ST165 - 78K - Project --->
Postby Fox 21 Alpha » Fri Jul 05, 2013 8:49 pm
There's myself and one other guy located in Pittsburgh that I know of. I agree with the above, check for spark, then fuel, then air. If you have all 3 and your timing isn't completely backwards it should atleast kick
Fox 21 Alpha
Postby mx6er2587 » Sun Jul 21, 2013 6:17 pm
I'm in Pittsburgh and am frequently up in the butler area. Let me know if you need any help
Return to NorthEast
