S.E - What did you do to your Trac today.
All the way to Sunny FL
Postby GT4_DRED » Fri Mar 21, 2008 2:38 am
for those of us looking for some inspiration :(
To answer the topic - Not a dang thing! :shrug:
GT4_DRED
Postby BLOWNTACO » Fri Mar 21, 2008 2:17 pm
Pulled the motor out of mine, and is currently still hooked to the hoist!!
A wise and frugal government, which shall leave men free to regulate their own pursuits of industry and improvement, and shall not take from the mouth of labor the bread it has earned - this is the sum of good government.
-Thomas Jefferson
BLOWNTACO
Postby BLOWNTACO » Sun Apr 06, 2008 1:32 pm
Update!!
The engine is torn apart into a millions pieces!! YAYYYYYYY!!!! :twisted:
-Thomas Jefferson
BLOWNTACO
Postby Nitro_Alltrac » Sun Apr 06, 2008 3:55 pm
May finally have mine back on the road. So far my electrical gremlin hasn't reappeared.
Mike
92 All Trac - Daily Driver
Nitro_Alltrac
Postby CMS-GT4 » Sun Apr 06, 2008 4:36 pm
Sun is out, I am heding out to work on my shortly.
Postby gt4rcdude » Sun Apr 06, 2008 7:26 pm
Raised my suspension 12mm. Re-torqued rear spacer. Removed .25 inches of pine pollen. Cleaned and detailed. Re-greased the rear swaybar bushings. Installed Jen-U-wine TRD shift knob. About to go out and get bugs on it.
gt4rcdude
Postby GT4times2 » Mon Apr 07, 2008 9:43 pm
1.Cleaned some parts, continued prepping subframe pieces (they were sand blasted a few months ago, just sanding/priming and applying chassis paint to them).
2. Started prepping some interior panels pieces, going to dye them black (SEM Landau black). That blue interior has got to go.
Frantz
12 Toyota Sienna LE (The Daily Pacifier)
05 Toyota Avalon XLS
90 ST185 Gen4
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
GT4times2
Postby GMan » Mon Apr 07, 2008 10:34 pm
> GT4_DRED
> Joined: 08 Apr 2007
I cleaned the foot mats out of the Camry All_Trac. :D
(does That count ? :shrug: )
I have to get motivated to work on the ST185. :roll:
# GT4times2
# Location: Florida
# Posted: Mon Apr 07, 2008 9:43 pm Post subject:
# 1.Cleaned some parts,
# 2. Started prepping some interior panels pieces,
So productive Frantz ! :D
It has been To COLD and dreary to do much up North.
Hopefully spring will arive soon.
Regards;
GMan
Postby gt4rcdude » Tue Apr 08, 2008 12:51 am
Got more bugs on it :D
gt4rcdude
Postby vip09 » Tue Apr 08, 2008 8:40 pm
Installed new piston rings, installed another set of ARP head studs, torqued the head down, cleaned up misc engine parts..
Just getting prepared to drop the engine back in.
vip09
Postby CMS-GT4 » Tue Apr 08, 2008 11:59 pm
I looked at it, got mad and kicked stuff.
Postby Gary » Wed Apr 09, 2008 6:36 am
CMS-GT4 wrote:I looked at it, got mad and kicked stuff.
Way to go Josh :lol:
93 ST185
Gary
Postby BLOWNTACO » Mon Apr 14, 2008 6:18 pm
What I did this weekend...Pulled #4 connecting rod only to find it has been spun....FUN!!!! :P
-Thomas Jefferson
BLOWNTACO
Postby gt4rcdude » Mon Apr 14, 2008 8:58 pm
Friday found clunking source, loose sway bar link. Upon which I found my diff mount cracked. Removed it today, cleaned out all the old rubber and filled it with urethane. It's like it knows the big meet is coming up.
gt4rcdude
Postby donteatbugs » Tue May 06, 2008 5:38 am
pulled my head and pistons and cleaned them. left the block in the car with the trans.
donteatbugs
Return to SouthEast
