S.E - What did you do to your Trac today.
All the way to Sunny FL
Postby CMS-GT4 » Tue Dec 30, 2008 8:48 pm
I found my gas leak, power washed my gas tank cover to strip the paint and am trying to figure out where I will locate my battery tray.
Postby vip09 » Wed Dec 31, 2008 1:10 am
I stripped down a 5S block to prep it for the machine shop. :)
vip09
Postby vip09 » Tue Jan 06, 2009 10:19 pm
Worked more on the 5S block. Drilled the coolant passages and blocked off the oil feed for the balance shafts.
vip09
Postby etantshi » Fri Jan 16, 2009 12:08 pm
I thought about my AT, that's about all I did to it. It might be time to actually work on it.
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby CMS-GT4 » Fri Jan 16, 2009 3:59 pm
I am waiting for the weather to get out of the teens...
Postby GT4_DRED » Sat Jan 17, 2009 8:52 pm
etantshi wrote:I thought about my AT, that's about all I did to it. It might be time to actually work on it.
I second that.. Temperature has been in the teens and twenties all bloody week.. :shrug:
'88 ST165 - project "Rahtid"
'91 MR2
GT4_DRED
Postby CMS-GT4 » Mon Feb 09, 2009 8:21 pm
Painted gas tank bits, fixed the fuel line and put it all back together. Now I have a spot of rust to kill then its ready to paint.
Hows everyone else project going?
Postby gt4rcdude » Mon Feb 09, 2009 9:32 pm
washed it!
gt4rcdude
Postby vip09 » Tue Feb 10, 2009 12:14 am
My 5S block and 3S head are ready for the machine shop. I just need to order some stroker pistons from ATS and I will be ready to build it.
vip09
Postby GT4times2 » Tue Feb 10, 2009 2:02 am
Since I have not posted in this section, here's a rundown of the latest things I have been doing. Been busy.
ST165
The block is at the machine shop getting cleaned, bored and honed.
Gathering parts for the rebuild.
Suspension pieces got factory bushings pressed off/ Polyurethane pieces going in soon after.
Valve cover getting powdercoated (dark gray)
Misc items getting powdercoated as well (brackets, mounts etc)
Subframe getting prepped for painting.
Devising a dual pump fuel system (two Walbros, Y set up, etc)...
Will be stripping interior soon. (contemplating full stripping of interior, remove oem sound deadning material, paint (sinlge stage urethane), then dynamat some sections. I want to spray it myself. Any suggestions for which paint gun to use? I want to do a good job, and know single stage is somewhat forgiving, and the fact that it's white helps a bit (plus it will be covered in carpet anyways).
I need some opinions on this. I have most interior pieces for a full conversion from blue to black (minus dashboard and a few panels here and there). I had a clean black one, and regret selling it :doh: . Now I must resort to either sourcing a black dashboard from a GTS at the junkyard or dye this one. I already dyed some plastic pieces with SEM dye, and works great. I haven't done the dashboard yet fearing the possibility of keeping or going back to blue, just in case I want the interior to stay blue (weak chance of that happening, but one never knows).
I dont mind the blue interior, but prefer black. Any opinions if I should stick to blue, and save the black pieces for a rainy day (other Alltrac that may need it in the future... :P ) or maybe cover the dash in a different material altogether.
By the way, does anyone have a reputable place that will thermal coat the factory manifold in the Southeast? I thought of Swain Tech coatings in NY, but if anyone has one closer, and does good work, I'd appreciate it.
Frantz
12 Toyota Sienna LE (The Daily Pacifier)
05 Toyota Avalon XLS
90 ST185 Gen4
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
GT4times2
Postby BLOWNTACO » Tue Feb 10, 2009 10:34 pm
Have you tried contacting these guys?
http://www.hpcoatings.com/
A wise and frugal government, which shall leave men free to regulate their own pursuits of industry and improvement, and shall not take from the mouth of labor the bread it has earned - this is the sum of good government.
-Thomas Jefferson
BLOWNTACO
Postby GT4times2 » Wed Feb 11, 2009 2:00 am
Thanks. I will check them out. Anyone dealt with them firsthand? Pricing info?
Frantz
90 ST185 Gen4
GT4times2
Postby 91sofla » Fri Feb 13, 2009 3:19 am
Frantz,
I think I remember someone local talking about thermal coating. Can't remember if it was here or on the MR2 forum.
It might have been Todd.
--Kim
06 Mini Cooper S
08 Evo MR
91sofla
Postby GT4times2 » Fri Feb 13, 2009 6:53 am
Kim, please if you can get the info, I'd appreciate it.
Frantz
90 ST185 Gen4
GT4times2
Postby magnum » Fri Feb 13, 2009 2:57 pm
Bought a set of G-Games 77 Wolf wheels. 18x8.5+30 mm front and 18x9.5+20mm rear.
magnum
Return to SouthEast
