Switch to full style
All the way to Sunny FL
Post a reply
FS: 3SGTE out of a 93 MR2 - $200 - Clearwater FL
Sat Jul 31, 2010 6:37 pm
2nd gen, 2nd revision 3SGTE
this is just for the motor minus the intake.
no turbo, no ecu, no wiring harness.
I was going to build this motor and use it in my all-trac but I now need a boat motor more than the all-trac needs a built motor.
Motor had about 120k miles when pulled and ran ok, it has been sitting out and un-ran for a while so it may need a rebuild. Comes with a non-lsd MR2 trans that is still attached to it.
Pick up only
Post a reply
