88 for sale in South Carolina
All the way to Sunny FL
Postby Guest » Sun Jun 26, 2005 10:35 pm
I have decided that I have too many cars and one must go. Kitt is the unlucky victim. It is an 88 model, black with gray interior, carbon gauge plate with autometer phantom boost and water temp gauges(green to match interior lighting). Blitz turbo timer and blow off valve, kyb adjustable struts all around and turbo xs manual boost controller. the Boost cut mod has been performed and is set at 14 psi, but boost is set at 10 psi. Recent timing belt, water pump, and other needed maintenence performed. Msd wires and coil also added. battery relocated to trunk also. the current turbo seals are bad but I have a replacement that needs to be installed, not interested in doing it myself- I have 2 other more involved projects. Engine runs excellent, tranny has slight grind in third gear at higher rpm Quick shifts.I have always wanted an alltrac and after 5 years of looking I found one only to realize its not the car for me.I am asking a firm $2600(I'm already taking a loss at this price)I am located in South Carolina. My name is Steven, you can email me if interested.
Postby Toxygene » Tue Jun 28, 2005 7:58 pm
Can you post some pics?
Postby etantshi » Tue Jun 28, 2005 8:30 pm
Email sent.
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
Postby Guest » Tue Jun 28, 2005 8:57 pm
Pics should be up in a day or two. sorry for the wait.
Postby Guest » Wed Jun 29, 2005 8:51 pm
Got pics now send email and I'll reply with pics.
Postby Guest » Tue Jul 05, 2005 4:42 pm
Return to SouthEast
