Switch to full style
The heartland
Post a reply
Fri Nov 27, 2009 10:34 pm
For starters, a new hood. What time are we doing the meet?
Fri Nov 27, 2009 11:30 pm
i could just hack my hood up :P not. 12, or after. if that works for you guys?
Fri Nov 27, 2009 11:34 pm
I think I still have the hard line that go over the trans. The small hoes is a maybe.
To easy to convert to air to air front mount. Even easier for ata top mount, no air flow to it will be bad but you can always put a scoop in you hood. I will be doing the conversion as well over the winter.
What time we meeting up for sure? 12 is ok for me. I need to plan my day bc I will have to go to school to work on some shit.
Joe you still have the same number?
Fri Nov 27, 2009 11:50 pm
Yea I got the same number. Noon is good for me but Ima be hung over as f***. So I may not be of any use.
Sat Nov 28, 2009 12:28 am
12 is good then. 12 it is.
Sat Nov 28, 2009 2:32 am
Chris can you confirm with Jeremy also.
Sat Nov 28, 2009 3:05 am
Already done. He'll be there around noon. :)
I'll bring my extra ATA intercooler just in case. We can always just try to start and run the car for a bit w/o the hood. This way, we can see if the intercooler is really the problem.
~Chris
Sat Nov 28, 2009 3:35 am
Good call^
Sat Nov 28, 2009 4:23 am
def good call. we can just put it on the futon in the garage. i really want to thank you guys for doing this. it means alot that you guys are coming to help lol. thanks again
Sun Nov 29, 2009 4:34 am
I would like to thank everyone that came out today. It meant alot. And i would also like to apologize for not being able to BBQ. everyone is invited back over winter break for food. Thanks again.
just wanna know if itd be ok to run it around the block, out of boost?
Mon Nov 30, 2009 3:37 am
Might be alright. I'd get that thermostat changed first.
~Chris
Mon Nov 30, 2009 5:52 pm
well i didnt get to start it before i left, let alone drive it around the block. so im just gonna pick one up this week.
Tue Dec 01, 2009 11:20 pm
Trust me its better to be patient especially with these cars. I never even drove my white car at all and I worked on it for two years straight. I took my time with the important stuff and its paid off.
Wed Dec 02, 2009 5:16 pm
yeah your right. im gonna make sure everything is in good working condition, and if that means driving it around a little bit, then ill make sure everything i need to replace or repair is already taken care of, before i even venture around the block.
wheres a good junkyard? i need to find another fourth gen for the headlight module. or does someone know of one that is just sitting?
Post a reply
