Greetings. Need some motor pull advice.
Postby pizzaguy » Mon Dec 12, 2005 9:11 pm
ok so i just bought an 88 165 that needs alot of work. After basic maintinance, i managed to lock up the motor on the test drive. I've done plenty of motor pulls, but never on one of these, and was just looking for hints and tips. i did search, but didnt find what i was lookin for. Thanks in advance
Daniel
pizzaguy
Postby InitialD93 » Mon Dec 12, 2005 9:21 pm
its lots of fun... ive done 3 this year... yay :doh:
Dustin
1990 All Trac w/ RC bumper, converted to 93
^^^ Old project about to start a new life ^^^
InitialD93
Postby CMS-GT4 » Mon Dec 12, 2005 9:35 pm
We dropped my motor instead of pulling it. May be easier on your. You definatly want something that can help with the gearbox. Imagine a gearbox that weights as much as most honda engines.
Shame you still wern't down here dustin, you could give him a hand. :D
I would look for a bgb online for the 165 so you have reference for all the wiring and hoses.
Speaking of engines, I need to go pick up my old engine so I can salvage whatever from it.
BTW: Dustin's method requires, metal music, a hammer, and head bangin.
Postby InitialD93 » Mon Dec 12, 2005 10:00 pm
:smokes:
Dustin
InitialD93
Postby pizzaguy » Mon Dec 12, 2005 10:15 pm
so, do i need to pull the gearbox out as well, or can it stay in the car?
pizzaguy
Postby Cashback » Mon Dec 12, 2005 10:23 pm
Do yourself a favor and drop the engine with the tranny, change the clutch and clean everything up. I had like ten pounds of dirt and grime covering my engine, tranny, and bay.
When dropping the engine, the higher you can get it the better, taking off the bumper helps a lot too.
Cashback
Postby CMS-GT4 » Tue Dec 13, 2005 2:58 am
I would drop both. Doing the gearbox alone is quite a job. I know yours has low miles, but I would at least check out the rear main, and maybe clutch disc.
Few performance items to concider as well. Maybe a stainless clutchline and shifter bushings. Those are both items that make the shifting of this car better. Its one of the strongest gearboxes you will find, but its a bitch to take out when you want to.
Check out this section for some info that might help.
http://alltrac.net/tuning/
http://www.celicatech.com/imagearchive/ ... gb.php#4th
http://gtfour.ca/
Postby SuperWhite92 » Tue Dec 13, 2005 3:31 am
Shaun
SuperWhite92
Postby Guest » Tue Dec 13, 2005 3:48 am
Thanks! i'll certainly look into dropping it out the bottom.
Guest
Postby All4Traction » Tue Dec 13, 2005 3:57 am
Replace AS MUCH AS YOU CAN, you really dont wanna pull that motor more than necessary. Ive done it once by myself, id rather not do it again if i didnt have to.
Paul S.-
89 Celica Turbo 4WD- Jdm ST-185 swap, CT20B turbo, ST205 A2W I/C....
http://turbo4wd.topcities.com/
All4Traction
Postby CMS-GT4 » Tue Dec 13, 2005 1:35 pm
Do a search for "hose from hell" and I would concider replacing most of the hoses anyway.
Are you doing forged internals or stock? Did you decide to rebuild it or find another engine?
Postby Guest » Sat Dec 17, 2005 7:10 pm
i've been working all week, covering shifts for like 4 people who caught the flu, so the motor isnt out yet. :x
Guest
Postby silence » Sat Dec 17, 2005 9:38 pm
I did a small photo/writeup on a 165 engine pull. It might be useful to you.
http://angrycamel.com/gallery/album66
06 WRX, 90 Celica Alltrac & 88 BMW TURBO 325is
http://www.youtube.com/watch?v=Ei5P9LfLRdg
silence
Postby CMS-GT4 » Mon Dec 19, 2005 4:52 pm
Any updates?
Postby Guest » Mon Dec 19, 2005 8:15 pm
going to work on it right now. first chance ive had all week. I should have it ready to pull out tonight, and actually have it out this week.
Guest
Return to New Member Forum
