performance for stock 3sgte
Postby MAT ALL-TRAC 92 » Wed Feb 15, 2006 11:57 pm
can I run 15psi with stock 3sgte (injectors+ecu stock) without problem and how I should ajust the timing for the distributor( stock timing or advanced) Thanks guys :P
MAT ALL-TRAC 92
Postby RIalltrac » Thu Feb 16, 2006 12:11 am
your not just going to be able to run 15 psi, the ecu will make sure of that. Your going to need to install an fcd and even then 15 psi is pushing it on all stock hardware. I hope you have all the appropriate guages to monitor things. I wouldnt mess with the timing, the ecu will do a good job of adjusting it as need be. Unless you go too extreme and the ecu cant keep up.
Chris - 90 ST185
RIalltrac
Images: 2
stock 3sgte
Postby MAT ALL-TRAC 92 » Thu Feb 16, 2006 12:42 am
I read in others sections that I can run until 15psi and the ecu will map the fuel OK and the stock injectors can handle 14 to 16psi? Could it be right and I want to be sure of that. Some say that I don't need fcd depending of wiring resistance because of the age of the vehicule.
Other info, what trannny I should use for a 3sgte but FWD??????Only mr2 or there is some others.
MAT ALL-TRAC 92
Postby MetalliKAT97 » Thu Feb 16, 2006 12:55 am
Depends on the ECU my 92 got away with 15 psi without a FCD and my 93 is running 16psi without a FCD as well....some guys can run it some cant...ECU wise
1993 ST185 (Black)
1992 ST185 (Grey) R.I.P.
MetalliKAT97
Re: stock 3sgte
Postby db » Thu Feb 16, 2006 4:13 pm
MAT ALL-TRAC 92 wrote:I read in others sections that I can run until 15psi and the ecu will map the fuel OK and the stock injectors can handle 14 to 16psi? Could it be right and I want to be sure of that. Some say that I don't need fcd depending of wiring resistance because of the age of the vehicule.
You can run 15 psi fine with fuel cut removed (assuming your ignition components are in good condition as well as the rest of the car). But why are you asking about trannies when you have all-trac in your screen name? What car are you driving?
Dave
Black 1990 Celica Alltrac
Las Vegas, NV
db
Postby MAT ALL-TRAC 92 » Thu Feb 16, 2006 11:42 pm
Im driving an 1992 black st-185 but somebody that I know want's to but a 3SGTE in a 1991 st185 GTS FWD and I want to know what kind of tranny can fit this car. That's it buddy!
MAT ALL-TRAC 92
Postby maxaud » Fri Feb 17, 2006 1:36 am
MAT ALL-TRAC 92 wrote:Im driving an 1992 black st-185 but somebody that I know want's to but a 3SGTE in a 1991 st185 GTS FWD and I want to know what kind of tranny can fit this car. That's it buddy!
that would be a st184 if I believe correctly (not a st185), and the stock tranny should bolt right up.
-Dustin
maxaud
Postby toayoztan » Fri Feb 17, 2006 2:12 am
Or you could use the mr2 tranny and get their axles.
And maybe it's just me that's looking too much into this, b/c others assume you're using a different turbo, but your stock turbo won't handle well past 14psi. If you are using a different turbo, then with the FCD in place, you should be able to run fine.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby db » Fri Feb 17, 2006 4:07 pm
I used to run my turbo daily at 17psi in the colder months up in North Dakota. The CT26 is still doing great, but I got her down to 14psi right now for Vegas.
Dave
Las Vegas, NV
db
Return to New Member Forum
