Hello there, Newb here, Just got an st185
Postby Guest » Fri Feb 17, 2006 6:21 pm
Hello all, I just purchased my very own ST 185.
I have some questions for you though,
First off, in terms of torque split, does the 185 have a front wheel or rear wheel bias? Secondly, is there a way to adjust it/have someone else adjust it? Secondly, is it true that the MR2 turbo had the same kind of engine?
Any answers you can give are much appreciated!
-GripJackal
Guest
Postby db » Fri Feb 17, 2006 6:50 pm
1. The ST185 transfers torque roughly 50/50.
2. This cannot be altered with the stock equipment.
3. The turbo MR2s from 91-95(?) time period did have the same basic setup as the ST185s. However, some of the accessories were in different locations, and not all MR2 designed aftermarket items will work with the ST185.
Dave
Black 1990 Celica Alltrac
Las Vegas, NV
db
Postby MetalliKAT97 » Fri Feb 17, 2006 7:57 pm
Signup/Register and hang around some :D
1993 ST185 (Black)
1992 ST185 (Grey) R.I.P.
MetalliKAT97
Postby d1alltrac » Sat Feb 18, 2006 5:02 am
like said earlier....our cars use a viscous center LSD which makes it a 50/50 torque split that cant be adjusted...
and our engines are, basically, the same as an MR2 turbo...they both have the 3SGTE, again like said earlier... browse our forum and you will learn alot
oh yeah....welcome to the club!!
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby Guest » Sat Feb 18, 2006 5:06 am
welcome! post some intro pics...
Guest
Postby theUNYTEDone » Sun Feb 19, 2006 11:02 pm
welcome, welcome. yeah, the mr2s with the 3S GTE has a much more cramped engine bay compared to the 185s (which isnt much BIGGER, at that) but lots of parts are located in different places. like the MR2's side mount intercooler. whee! i really like mr2's...but i'm an all trac kid. lol
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby maxaud » Mon Feb 20, 2006 1:18 am
d1alltrac wrote:like said earlier....our cars use a viscous center LSD which makes it a 50/50 torque split that cant be adjusted...
I had the JDM TorSen on mine... is it still 50/50?
-Dustin
maxaud
Postby theUNYTEDone » Mon Feb 20, 2006 5:54 am
it should be. did you put it in after buying your car? was there any difference in performance compared to stock?
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby maxaud » Mon Feb 20, 2006 3:38 pm
it was in when I bought the car. It is only engaged when acceleration is apply'd, and not when slowing down. It seem'd to make the rear mount fill a lil' lose. it mix'd w/ my stage 3 clutch made it real easy to get the car sideways. The TorSen only has 13 moving parts so it is said to be more efficient.
-Dustin
maxaud
Postby db » Mon Feb 20, 2006 4:22 pm
Torsen is torsen. They should work the same.
Dave
Las Vegas, NV
db
Postby maxaud » Tue Feb 21, 2006 12:12 am
db wrote:Torsen is torsen.
huh?
I put "TorSen" because thats how I've seen it spelt everytime I've seen it.
TorSen= Torque Sensing (sp)
-Dustin
maxaud
Postby CMS-GT4 » Tue Feb 21, 2006 12:18 am
You mean torsen rear? Only VC made for the center.
No matter what the rear or front are the center will always be 50/50.
Postby maxaud » Tue Feb 21, 2006 12:20 am
yeah, my bad.
-Dustin
maxaud
Postby db » Tue Feb 21, 2006 4:09 pm
huh?
You are the first person I've seen spell it like that. Maybe its an Aussie thing? :shrug:
Dave
Las Vegas, NV
db
Postby maxaud » Tue Feb 21, 2006 9:26 pm
here is a page w/ it spelt both ways...
http://www.rallycars.com/Cars/4wd_turbo_cars.html#torsen
-Dustin
maxaud
Return to New Member Forum
