turbo manifold fitment issue
Postby theUNYTEDone » Sun Feb 19, 2006 11:07 pm
well i recently got in my downpipe and turbo manifold (ebay special, i believe) :doh: but haven't put them in yet, i'm almost positive the Dpipe will fit, it came with the support brack, all hardware, etc. so did the tubular manifold. however, there's a problem. i drive a 1990 ST185, and i found that the manifold has TWO EXTRA STUD HOLES! apearently the 92-93 185's had a 9 bolt configuration. mine has seven. will the manifold still fit despite the extra holes? and if so, would it be advisable to go through with installation? orrr...would it just be wise to try and pass it on and resell?
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby saved_1992 » Sun Feb 19, 2006 11:56 pm
it will fit, but then you need a different alternator braket
the easy thing to do is just cut off that corner of the manifold (left upper corner) the right upper corner should not be in the way of anything
mike
omaha,ne
1988 a driver (RED) sold
1992 the keeper (RED)
1993 sold to 2of81 (RED)
saved_1992
Postby theUNYTEDone » Mon Feb 20, 2006 4:53 am
if i cut the corner on the alternator side, will i still need a different bracket?
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby saved_1992 » Mon Feb 20, 2006 9:50 am
theUNYTEDone wrote:if i cut the corner on the alternator side, will i still need a different bracket?
if you cut that corner off it should fit just like your stock manifold, use your old manifold to know how much to cut off for a proper fit.
mike
omaha,ne
saved_1992
Return to New Member Forum
