recommended boost?
recommended boost?
Postby Guest » Thu Feb 23, 2006 12:21 am
what's the recommended highest pressure to run a CT26 (no mods) for a daily driver? im thinking...10 ish? well away from stock max boost and still far away from actual limit...
Guest
Postby omgitsroy326 » Thu Feb 23, 2006 12:24 am
14 st185
12 st165
omgitsroy326
Postby theUNYTEDone » Thu Feb 23, 2006 12:27 am
wow, really? and there won't be any problems/ shortened life span?
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby omgitsroy326 » Thu Feb 23, 2006 12:44 am
i've absorbed these numbers from this board...
before even doing this.. make sure everythin is replaced~
omgitsroy326
Postby SuperWhite92 » Thu Feb 23, 2006 12:45 am
theUNYTEDone wrote:wow, really? and there won't be any problems/ shortened life span?
On a good shape motor, you'll be fine. I did 14 all day long on my old motor/stock turbo, and now I'm up to 16 on the JDM motor with 46T upgrade.
Shaun
SuperWhite92
Postby db » Thu Feb 23, 2006 4:06 pm
I did 17 psi just fine for years up in North Dakota because of the mild weather and cold winters (great for intercooling!).
Higher boost will only shorten the lifespan on already worn and dying equipment.
Edit: I'm at 15 psi here in Vegas and will probably drop a few psi for summer again.
Dave
Black 1990 Celica Alltrac
Las Vegas, NV
db
Return to New Member Forum
