twin entry
twin entry
Postby patch » Fri Apr 14, 2006 12:21 am
i am looking at puting a twin entry turbo set up from a 185 on my 165. first can it be done?? what are some of the drawbacks and or plus of this set up?? and lastly where can i find info on how to do it??? thanks.
patch
Postby 2RM » Fri Apr 14, 2006 12:24 am
Alot of people have done it just use the search to find the info
2RM
Postby d1alltrac » Fri Apr 14, 2006 12:30 am
yes its possible. i have done this on my 165, i dont know of any benefits other than a little better spool that is hardly noticable, but the twin entry manifold/wastegate port isnt prone to cracking like the single entry.
check these 2 threads for info
http://www.alltrac.net/phpBB2/viewtopic.php?t=2136
http://www.alltrac.net/phpBB2/viewtopic.php?t=13203
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby theUNYTEDone » Fri Apr 14, 2006 1:07 am
i was reading some benefits of twin entry, i dont remember from what post/thread/website, though....but with twin entry, isn't it true that the manifold runners have better flow, due to less/no cylinder cycle clash? i thought it has better airflow...but then again, i suppose it would only result in a slightly better spool? :shrug:
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby toayoztan » Fri Apr 14, 2006 2:58 am
theUNYTEDone wrote:i was reading some benefits of twin entry, i dont remember from what post/thread/website, though....but with twin entry, isn't it true that the manifold runners have better flow, due to less/no cylinder cycle clash? i thought it has better airflow...but then again, i suppose it would only result in a slightly better spool? :shrug:
No, you're right. Because of the certain firing order, the twin entry doesn't cause as much "exhaust flow clashing" and here's something i actually just read last night to help explain a little. There's actually no drawbacks to switching over to twin entry.
http://www.turbobygarrett.com/turbobyga ... 102.html#c
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Return to New Member Forum
