headlight upgrade
headlight upgrade
Postby patch » Sat Apr 15, 2006 3:22 am
i heard about a upgrade for the headlights to use a h4 bulb. anyone eles heard about this???? cant find any links but i probly looking in the wronge place. thanks for any info
patch
Postby BanhBaoBao » Sat Apr 15, 2006 3:29 am
check ebay :)
BanhBaoBao
Postby Gary » Sat Apr 15, 2006 3:35 am
Might wanna check out this thread
http://www.alltrac.net/phpBB2/viewtopic.php?t=8448
93 ST185
Gary
Postby d1alltrac » Sat Apr 15, 2006 3:49 am
you can by an H4 conversion at any autoparts store
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby theUNYTEDone » Sat Apr 15, 2006 7:32 pm
i just need some clarification...these H4 adapters...are they basically plug and play? i'm really not familiar with lighting..
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby Wicked Toys » Sun May 07, 2006 2:31 am
Yeah I bought the H4 Headlight Housings for both my GT n Alltrac from Advanced Auto Parts. Yes its plug in play all you need is a phillips screwdriver and a worthy H4 bulb. Here's what mine look like with PIAA Star White Bulbs.
Wicked Toys
Postby omgitsroy326 » Sun May 07, 2006 6:15 am
please get raybrig...
omgitsroy326
Postby theUNYTEDone » Sun May 07, 2006 9:17 pm
hey wicked, what type of screws bolt the headlight shroud to the metal of the headlight assembly (shroud=the black plastic bit that goes around the actual headlight glass)....ive got the shrouds off, but no screws. :doh:
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby SuperWhite92 » Sun May 07, 2006 11:03 pm
theUNYTEDone wrote:hey wicked, what type of screws bolt the headlight shroud to the metal of the headlight assembly (shroud=the black plastic bit that goes around the actual headlight glass)....ive got the shrouds off, but no screws. :doh:
There's two or three philips head screws that usually hold it on.
Shaun
SuperWhite92
Postby theUNYTEDone » Mon May 08, 2006 11:35 pm
so can they just be pretty much anything that fits? or does it need a specific thread pitch? i wanna put mines back on...car looks a bit skeleton-ish without them. lol....but back to the H4's...one will need to get the bulb AND the correct housing, yes?
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby Wicked Toys » Wed May 10, 2006 2:46 am
theUNYTEDone wrote:so can they just be pretty much anything that fits? or does it need a specific thread pitch? i wanna put mines back on...car looks a bit skeleton-ish without them. lol....but back to the H4's...one will need to get the bulb AND the correct housing, yes?
Yes any small screw should work cause mine are all mixed matched between older n newer phillips screws. And yeah Im sure you can search n find out about the different housings and to my knowledge they use H4 series bulbs n thats it. Just put the bulbs in the spring mechanism n plug into your factory and your good to go. And of course make sure there lined up right.
Wicked Toys
Postby mabgibai » Thu May 11, 2006 1:29 am
The girl that had the all trac before me did the H4 conversion. I got to say its really sweet.
mabgibai
Postby theUNYTEDone » Thu May 11, 2006 7:37 am
mabgibai wrote:The girl that had the all trac before me did the H4 conversion. I got to say its really sweet.
what's pretty sweet is a girl that OWNS an all trac. :)
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby alltech72 » Thu May 11, 2006 9:31 am
went on ebay they have the halos now with the blue not sure of the quality they are only 40 bucks
st 165 mint, 93vr6 corrado, 92 lexus sc400
alltech72
1994 Toyota Celica
Postby jlspec » Fri May 12, 2006 4:58 am
Using any H4 conversion off ebay sucks. Instead of improving your night vision it actually worsens it. Go with raybrig and some real quality H4 bulbs and you'll see a difference. The silverstar replacement is pretty good. It's either slightly better then stock give and take what kind of lighting you want. The silverstar even out lights those cheap ebay H4 conversion. Hell I have a set of the ebay H4 that is brand new. It was given to me because they suck so bad the buyer didn't even care for them. Do a search and you'll see.
jlspec
Return to New Member Forum
