this is really a newb Q, coming from an old guy...LoL!
toayoztan
Thanks for the correction GMan. But however the VPC works, it still is limited, but for about 300awhp, it may be ideal.
Bryan
GMan
> toayoztan
> Location: Oklahoma City, OK USA
> Posted: Mon May 01, 2006 10:57 pm
Hi Bryan;
No problem.
Limited How ? By the fact is is hard to program ?
I agree with you in that case.
You would need a chip burner, or a friend with one. :)
For any hp you would care to have it tuned for ? :-}
It Only eliminates the AFM. On out cars May be around 300hp with a 550 chip.
But with a bigger turbo, and timing support BTM, or ITC, the sky is the limit ?
I said you can get a 720 inj chip. Toyomoto in FL probably
could tune even higher ? How well it would idle etc is a different
story, all dependent on the tuner/chip burner.
Supras get Sick hp out of just a VPC removing the AFM.
(and turbo + fuel upgades)
The VPC is a mixed bag. Good and bad. It is plug and play,
but not ideal for a full tune of fuel and timing.
For the cost new, it is not worth it, but since they were
discontinued, they are pretty good deal used. :)
For the usual owner it may be all that is needed to
break 300 hp ? A full ems is a better way to go in
the long run If you can afford the unit and tuning. (or do it yourself ? :)
Regards;
