st165 hood
st165 hood
Postby alltech72 » Mon May 08, 2006 11:31 pm
im looking for the best hood out there for my st165 i prefer one with a scoop i want to put an bigger water to air intercooler or fmic
st 165 mint, 93vr6 corrado, 92 lexus sc400
alltech72
1994 Toyota Celica
Postby theUNYTEDone » Mon May 08, 2006 11:33 pm
then try finding one with a vent, rather than a scoop (the WTA intercoolers handle with just a vent) <--- just look at the Rally spec 185's...and 205's. other than that...i know there was a bloke from UK (165 named betsy) who had an evo style vent on his car...try finding him and chatting it up about sources/etc.
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby alltech72 » Mon May 08, 2006 11:37 pm
are the specs the same for the hoods versus the st165 st 185
alltech72
1994 Toyota Celica
Postby theUNYTEDone » Mon May 08, 2006 11:40 pm
im pretty sure if you look at a pic of a 185, and then at a pic of a 165, the hoods will be TOTALLY different... :doh:
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby d1alltrac » Tue May 09, 2006 12:07 am
there arent any aftermarket hoods that i know of for the 165, there might be a couple for 162's that would work but i havent seen any.
i would say your best bet would be to find the vent or scoop you want online or something, then buy a junkyard hood from a 162 and mold in the vent or whatever.
there was supposed to be some carbon fiber 165 hoods with RC style vents made a while back but i dont think it ever actually happened.
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Re: st165 hood
Postby Gary » Tue May 09, 2006 12:42 am
alltech72 wrote:i prefer one with a scoop i want to put an bigger water to air intercooler or fmic
Why would you want a scoop if your are going with w/a IC or FMIC?
93 ST185
Gary
Postby alltech72 » Tue May 09, 2006 1:23 am
more for the look, ill probally get a carbon fiber one. you said the 162 hood may fit
alltech72
1994 Toyota Celica
Postby d1alltrac » Tue May 09, 2006 2:00 am
alltech72 wrote:more for the look, ill probally get a carbon fiber one. you said the 162 hood may fit
162 hoods will fit (my hood is off an ST) but if you are going with a 185RC/205 intercooler you will probably run into the same clearance issues with the stock hood since they are the same. with an aftermarket 162 hood there is no telling, i dont even know of any aftermarket 162 hoods though.
also, you may want to consider a vent instead of a scoop, a scoop wont help with anything other than looks but a vent will significantly lower under hood temps and they still enhance the appearance too. that and non-functional hood scoops are gay IMO.
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby alltech72 » Tue May 09, 2006 2:09 am
my hood has the protection its coming off will it be a problem if i remove it
alltech72
1994 Toyota Celica
Postby d1alltrac » Tue May 09, 2006 2:09 am
no, just rip that shit out.
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby alltech72 » Tue May 09, 2006 2:53 am
done just though i still needed it
alltech72
1994 Toyota Celica
Postby theUNYTEDone » Tue May 09, 2006 6:56 am
the hood lining is just for sound reduction, right? does it actually raise the engine bay temperatures as well?
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby esracing » Wed May 10, 2006 3:25 am
here is a pic of mine 162 hood with hole cut in it and fiberglass screwed to it :smokes: [/img]
(442.5 KiB) Downloaded 33 times
(156.32 KiB) Downloaded 29 times
2008 tundra blue
1988 st165 white imsa gto
1969 camaro 502 bb 630 hp black
esracing
Postby theUNYTEDone » Wed May 10, 2006 9:39 am
i remember this! where'd you pick up the CS vent from?
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby haireball9 » Fri May 12, 2006 2:54 pm
so which is better to vent it and let the hot air out, or scoop and force cold air over the intercooler?
or is it just personal preff?
88 Alltrac
Supra Kid 95: i'll let you drive my alltrac
haireball9
Return to New Member Forum
