bov question
bov question
Postby marklar88 » Tue Aug 29, 2006 8:34 pm
this is a seriously newb question that i am almost embarassed to post... bovs are hooked up btw the ic and turbo, right?? how is it that coolant is not released when pressure is?
88 alltrac: hks exhaust, hks timer, koni struts, intrax lowering springs,
marklar88
Re: bov question
Postby SuperWhite92 » Tue Aug 29, 2006 8:46 pm
marklar88 wrote:this is a seriously newb question that i am almost embarassed to post... bovs are hooked up btw the ic and turbo, right?? how is it that coolant is not released when pressure is?
A bov is installed anywhere between the throttle body and the compressor(intake) side of the turbo. It can go anywhere, since it's purpose is to relieve the pressure caused by the sudden closure of the throttle body in the intake tract.
The reason that coolant isn't released is that it has no relation to the intake tract. Air flows through the intake part of the intercooler and transfers it's heat into the metal along it's path inside the intercooler. The WTA intercooler's water flows through a seperate system, and is continually pumped to carry the heat away from the intake system. The water itself (and the coolant in the intercooler system) only comes in contact with the outside of the metal which the air is transferring it's heat to.
Kinda hard to explain on the internet. let me know if I can clarify anything for you.
Shaun
SuperWhite92
Postby Gary » Wed Aug 30, 2006 1:03 am
Instead of cooling the core by air flow (like a/a FMIC or ST185 TMIC), W/A IC cools the charged air by passing the coolant around the IC core.
Think of an air-to-air intercooler core stuffed in an aluminum tank filled with coolant.
Then, you pump the coolant and let it flows through the system.
It carries the heat from the the core (which has charged air inside) and
releases it out at the heat exchanger mounted on the front of the car.
So, there are two separated systems (charged air and liquid)
The BOV vents pressure from the charged air system.
So, it has nothing to do with liquid system.
93 ST185
Gary
Postby marklar88 » Fri Sep 01, 2006 7:42 am
im sorry I just dont understand :shrug: i just cant visuallize it.
marklar88
Postby syko says » Fri Sep 01, 2006 7:49 am
Gary wrote:Think of an air-to-air intercooler core stuffed in an aluminum tank filled with coolant.
so think of a reg ATA IC attached with a bov... put it into a metal box around the ATA core (not around bov)... add some coolant into the metal box.. cover the box.. and taw daw youve made yourself a WTA IC.. (not really but you know). id really draw it out Gary style, but its late in hawaii, and im tired. its not really hard to understand. youre probably thinking too hard :P
Aloha,
Evan
syko says
Postby Gary » Fri Sep 01, 2006 6:11 pm
93 ST185
Gary
Postby syko says » Fri Sep 01, 2006 9:19 pm
YAY! Gary style paint!! hope this clears up some confusion marklar
Aloha,
Evan
syko says
Postby marklar88 » Sat Sep 02, 2006 4:28 am
ok, i think that I have it, the charged air flows back thru the ic and passes the fins containin coolant and thats what cools it b4 it goes into the throttle body?? I almost have it please work with me, I was the little bastard that always needed a little extra attention from the teacher in 3rd grade(not dumb, just takes a while for the momentum to build)
marklar88
Postby MetalliKAT97 » Sat Sep 02, 2006 4:59 am
gatta love paint...makes things easier :wink:
1993 ST185 (Black)
1992 ST185 (Grey) R.I.P.
MetalliKAT97
Postby Gary » Sat Sep 02, 2006 11:56 am
You got it.
That fin is called "IC core"
93 ST185
Gary
Postby marklar88 » Sat Sep 02, 2006 6:56 pm
thanks guys :D
marklar88
Return to New Member Forum
