Powder coating
Powder coating
Postby 7thGenDragon » Wed Sep 06, 2006 5:41 am
OK,
a thought recently crossed my mind,
Would it be possible to powder coat the TMIC on a ST165? are there any drawbacks of it? Would there be any gain from having it powdercoated?
2004 Mazda Rx8 GT- In love.
2002 Celica GT- In a parking space
1988 Alltrac- In for a new motor
Something is Always Broken...
7thGenDragon
Postby turbo4wd » Wed Sep 06, 2006 11:36 am
Powdercoating something is for purely cosmetic reasons.. There would be no performance gain.. If anything it may hurt performance if a person were to put it on a A2A heat exchanger.. But since you're talking about the W2A heat exchanger of the st165, I think you'd be ok.. I've seen people paint their 165 intercoolers without any problems..
Dan
Undercover Moderator
turbo4wd
Postby 7thGenDragon » Wed Sep 06, 2006 6:44 pm
thanks for the info.
7thGenDragon
Postby toayoztan » Wed Sep 06, 2006 8:14 pm
I don't know about powdercoating, but people have said it's okay to paint A2A intercoolers (specifically, they told me FMIC anyway) and won't hurt performance. Don't know if that's true or not. A little offtopic for you since you have 165, but just thought i'd throw this out here!
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby theUNYTEDone » Thu Sep 07, 2006 9:25 am
toayoztan wrote:I don't know about powdercoating, but people have said it's okay to paint A2A intercoolers (specifically, they told me FMIC anyway) and won't hurt performance. Don't know if that's true or not. A little offtopic for you since you have 165, but just thought i'd throw this out here!
Bryan
i heard of GReddy or someone putting out a black intercooler, and they tested it vs a regular one. said to have no drawbacks of absorbing heat or anything.
as for powdercoating the top mount 165 cooler, i'd say not to waste time, unless you intend on prettying up the rest of your engine bay like that. it'll add weight, too. not much, but still something to keep in mind.
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby MetalliKAT97 » Thu Sep 07, 2006 9:38 am
What about ceramic coating something like the I/C?
better/worse/no change at all/no point?
1993 ST185 (Black)
1992 ST185 (Grey) R.I.P.
MetalliKAT97
Postby edv-tek » Wed Sep 20, 2006 11:57 pm
The ic in a 165 is a little difficult to ceramic coat. You would have to separate the internal radiator with the outer housing. You are better off heat wraping it or an aluminium heat sheild underneath. Plus a bigger heat exchanger and pump running continously.....would be nice.
Ed Vaughan
White Supercharged Previa LE Alltrac w/beige leather 208K and counting
1988 Mercedes Benz 560SL 42K
Maryland
edv-tek
Postby toayoztan » Thu Sep 21, 2006 2:22 am
MetalliKAT97 wrote:What about ceramic coating something like the I/C?
I wouldn't suggest this. You have to remember, ceramic coating is usually used for stuff that gets hot and you DON'T want it to radiate the heat off into the engine bay. Well, it kind of works the opposite way too. If you ceramic coat the intercooler, it may hinder the air helping it to cool the IC down, and to add, you'll just be trapping in the heat inside the IC because of the ceramic coating.
This makes sense because when you ceramic coat exhaust components, you're ideally wanting to trap the heat in for two purposes. First, so the heat doesn't radiate and soak the engine bay hot. Secondly, because exhaust gases "move" along better at higher temps (or so i was told and read and heard and...you get the point).
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby Gary » Thu Sep 21, 2006 3:16 am
I think she meant coating the exterior of ST165 W/A IC.
Not the core, but the exterior of the IC to protect the water from warming up by the heat in the engine bay.
It should work the same way as wraping it with heat shielding material.
93 ST185
Gary
Return to New Member Forum
