extension taken off orignal shifter.....
Postby smog7 » Fri Oct 06, 2006 6:28 pm
ok well i talked to one of the previous owners of my car and he said that he took off an extension of the shifter to make it shorter...... should i try and find the extension piece if i can? im not sure if i can place a shift ball on it due to the fact that their are no threads on it..... sorry for the big pick
-omar
rally tarmac 1990 st185
smog7
Postby smog7 » Fri Oct 06, 2006 7:01 pm
heres some better pictures...
the white thing is a broken off piece of the shitty shift ball...
-omar
smog7
Postby HaPpYfAcE » Fri Oct 06, 2006 7:21 pm
you're going to need a shift knob that secures with a hex screw or just a screw on the side that you can tighten down.
i know that there is a certain momo knob that does this, but i don't have one nor do i know which model it is specifically.
2010 STi
95 MR2 na-swapped - sold :(
90,92 Alltracs - sold
HaPpYfAcE
Postby Qlynxer » Fri Oct 06, 2006 7:35 pm
I would just upgrade to an acutal short shifter. TWM makes a great shifter that will have threads on it so you can screw on any shift knob. One of the best mods for the all-trac and not too expensive either.
Quan L
Santa Ana Ca
Qlynxer
Postby smog7 » Fri Oct 06, 2006 7:47 pm
yeah im too poor right now to buy a short shifter, but in the future hopefully i will invest in one. as for now, i think im going to glue the knob that i have to the shifter.. any glue or epoxy recommendations?
-omar
smog7
Postby Qlynxer » Fri Oct 06, 2006 8:00 pm
short shifter > BOV :wink:
Santa Ana Ca
Qlynxer
Postby smog7 » Fri Oct 06, 2006 8:20 pm
around how much do they go for?
-omar
smog7
Postby Gary » Fri Oct 06, 2006 8:31 pm
Stock shifters from 1992-1998 FWD Celica are bolt on and have shorter throw than 90-91 shifter. I bought one for $15.
93 ST185
Gary
Postby Qlynxer » Fri Oct 06, 2006 8:32 pm
http://www.twmperformance.com/shortshif ... ifters.htm
Can be had for cheaper if you look around for a used one.
Santa Ana Ca
Qlynxer
Postby tw2 » Sat Oct 07, 2006 2:30 am
You can easily add threads to it. Just get a tap and die set and do it yourself or take it to your local fabricator- shouldn't cost more than $5 to do. If you want it longer simply weld some metal bar onto it, if it is stuck in a lathe and then welded properly it should be very strong and function very well.
Thomas, JDM 90 185, 06 350z
tw2
Postby Denver_whiteST185 » Sat Oct 07, 2006 4:14 am
heres a slightly cheaper subsititute
https://shop.ptmotorsports.net/category ... tegoryId=4
i would get the 92-93 one. they're preaty much stock shifter that have been welded down a little. i have not had any experiance with them, and seeing that its a new company, i would give them a call and place the order over the phone....
^Ted^
Denver_whiteST185
Return to New Member Forum
