noobie all-trac question
Postby amir904 » Tue Oct 24, 2006 1:47 am
im very new to the all-trac. i might buy a 88 this week. :D im almost set on one. what exactly is a BOV good for? i know its used to dump boost pressure when the throttle is closed but is it needed? if it were, wouldn't every turbo engine come with one? does it really add performance?
amir904
Postby Stubble » Tue Oct 24, 2006 1:55 am
no added performance. some people like the sound when it blows. It is useful for protecting the compressor of a turbo when higher than stock boost levels are achieved.
Brady Ryall
1990 ST185 Red - parts
1990 ST185 Black
1999 Miata
2008 A3 Quattro S-line
Stubble
Postby smog7 » Tue Oct 24, 2006 2:05 am
so for stock boost a bov is a waste of money?
-omar
rally tarmac 1990 st185
smog7
Postby Gary » Tue Oct 24, 2006 2:41 am
alltrac7 wrote:so for stock boost a bov is a waste of money?
I think the reason the Toyota did not put a bypass valve on our cars because of the limited space. Even though I have seen CT26s from 100k + miles Alltrac with very little to no shaft play, I wouldn't say it is a waste of money.
93 ST185
Gary
Postby suprakid95 » Tue Oct 24, 2006 5:00 am
hey welcome to the boards, dont forget to post some pics after you get the bad boy.
suprakid95
Postby db » Tue Oct 24, 2006 2:48 pm
Toyota put bypass valves on stock MR2 turbos. If they thought they were a waste of money and resources, they would've left them off the MR2's, just like the Alltracs.
A bypass/blowoff valve keeps harmful boost from trying to flow backwards through the turbo. Even at stock boost, a bypass/blowoff valve is useful for longevity of the turbo.
Dave
Black 1990 Celica Alltrac
Las Vegas, NV
db
Postby smog7 » Tue Oct 24, 2006 3:07 pm
i dont get u guys...... i recently just ask in another thread if should invest in a bov and most of you said NO. it was stated that with stock boost a blow off valve was not needed??? do you guys just like to change your minds?
-omar
smog7
Postby db » Tue Oct 24, 2006 3:08 pm
I didn't answer in the last thread. :D
Dave
Las Vegas, NV
db
Postby Gary » Tue Oct 24, 2006 3:34 pm
db wrote:I didn't answer in the last thread. :D
Neither did I.
But did you know that the MR2 came with by pass valve, not BOV?
By pass valve will not mess up with your A/F ratio.
93 ST185
Gary
Postby toayoztan » Tue Oct 24, 2006 4:18 pm
Thus, we say in this thread, yes to BPV, definitely would not be waste of an investment.
You are probably confused b/c you don't know why they left them off our cars, but have them on the mr2. But we doubt they aren't important, b/c they did in fact put them on the mr2. However, like Gary said, it may be due to cramped space.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby smog7 » Tue Oct 24, 2006 4:32 pm
so investing in a by pass valve would be smart?
-omar
smog7
Postby Gary » Tue Oct 24, 2006 4:51 pm
alltrac7 wrote:so investing in a by pass valve would be smart?
Let's put it this way, it's not the first priority unless you have a brand new turbo or you want to keep this turbo forever. Remember that you will need to change your intake setup to accommodate the bypass valve. That means, new intake piping and/or straight intake and/or relocating the battery.
93 ST185
Gary
Postby smog7 » Tue Oct 24, 2006 4:53 pm
so i should most likely just wait untill i get a new turbo?
-omar
smog7
Postby CMS-GT4 » Tue Oct 24, 2006 4:56 pm
I would wait till you upgraded your turbo and IC. I think it does not make enough difference on a stock setup to bother.
Postby Gary » Tue Oct 24, 2006 4:57 pm
alltrac7 wrote:so i should most likely just wait untill i get a new turbo?
Good idea, especially if the current turbo is on its way out!
93 ST185
Gary
Return to New Member Forum
Users browsing this forum: Baidu [Spider] and 2 guests
