noobie all-trac question
Postby smog7 » Tue Oct 24, 2006 5:03 pm
ok ill wait untill the turbo swap
-omar
rally tarmac 1990 st185
smog7
Postby smog7 » Wed Oct 25, 2006 4:53 pm
what type of bov should i look for after getting the turbo? i heard that the hks one is not for stock boost?
-omar
smog7
Postby Gary » Wed Oct 25, 2006 5:09 pm
alltrac7 wrote:what type of bov should i look for after getting the turbo? i heard that the hks one is not for stock boost?
Who told you that? :bs:
HKS SSQV works fine on any level of boost. (sequential opening)
It also won't leak under the pressure. (pull type)
Are you planning to vent it to asmosphere or return it back (bypass valve setup)?
Not all valve can be set up as a BPV.
93 ST185
Gary
Postby smog7 » Wed Oct 25, 2006 6:49 pm
im not completely sure what i want to do, which would be best?? does one offer enything that the other doesnt? i read about the hks in the gt4oc forum.
-omar
smog7
Postby smog7 » Wed Oct 25, 2006 7:17 pm
whats the difference between a re-circ bov and other bov? should i just go with a bypass valve? what bypass valves are available for my car?
-omar
smog7
Postby Gary » Wed Oct 25, 2006 7:33 pm
BOV = vent out to atmosphere
Recirculate BOV = by pass valve = vent back to the intake before the turbo
There is no BOV or BPV that is bolt on to alltrac.
You will need to either weld a flange on the intercooler piping or use a T-hose.
Go here
http://alltrac.net/phpBB2/viewtopic.php?t=17324
On page 2, Wicked Toys has the flange welded on the stock IC.
I, on the other hand, use a Samco T-hose.
Both of us do not vent it back.
If you like a recirculation setup, you will have to find a way to plumb it back to the intake. (forget the stock intake)
On that same thread, go to page 1, Gary ST165 has a recirculation setup.
The air is vented back to the intake via a metal pipe (on the right of the upper coolant hose)
The cheapest and probably the best valve for our cars is the stock bypass valve from MR2T.
It has the similar design to HKS. It will not leak.
You can find it for about $50.
93 ST185
Gary
Postby smog7 » Wed Oct 25, 2006 7:58 pm
thanks for clearing it up for me. does a by pass valve offer any advantages over a regular bov, performance wise?
-omar
smog7
Postby Gary » Wed Oct 25, 2006 9:07 pm
alltrac7 wrote:thanks for clearing it up for me. does a by pass valve offer any advantages over a regular bov, performance wise?
On the car with VAM (flapper type AFM), the BOV causes car to run richer because it vents metered air out. The BPV does not do that. Other than this, the BPV is just quieter than the BOV.
93 ST185
Gary
Postby 88alltracohio » Fri Oct 27, 2006 7:06 pm
I was going to rebuild the ct26 and buy a HKS SSQV. The turbo has 150,000+ miles on it, how long do you think the turbo would last for.
88 ST165: SOLD :(
320hp sr swapped 90 240sx: SOLD
93 Del Sol: Daily driver
93 300zx: FOR SALE
I miss my AllTrac :'(
88alltracohio
Postby db » Fri Oct 27, 2006 7:51 pm
My CT26 has 205,000 miles on it without a rebuild or anything. And its been boosting 15-17 psi for at least 60,000 of those miles. Proper maintenance plus reasonable driving habits go a long ways with a turbo.
Dave
Black 1990 Celica Alltrac
Las Vegas, NV
db
Postby smog7 » Fri Oct 27, 2006 8:31 pm
so my 141000 mile ct26 should have at least a couple thousand more in it?
-omar
smog7
Postby db » Fri Oct 27, 2006 8:32 pm
If you treat it right, and don't have bad luck, you might have 60,000 miles left in it.
Dave
Las Vegas, NV
db
Postby smog7 » Fri Oct 27, 2006 8:38 pm
also just wondering if anyone uses an mr2t bpv on their car? anyone have any pics them? im really interested in getting one for my car.
-omar
smog7
Postby smog7 » Mon Oct 30, 2006 7:44 pm
nobody?
-omar
smog7
Postby gt4tified » Tue Oct 31, 2006 12:38 pm
When I put in my 3sgte (mr2) in I removed the stock rbov and put in an atmospheric one....only to realize from the guys here that I did a jackass thing by doing that...now I need to go visit that mechanic and hope that he still has the stock bov.
gt4tified
Images: 5
Return to New Member Forum
