couple of oil drops
couple of oil drops
Postby smog7 » Tue Oct 31, 2006 6:55 pm
well my car leaks 1-2 drops of oil after turning it off, i want to clean the engine, but im pretty sure i wont find the leak due to the reason that i dont know jack about cars (still learning) . ive been told its not a big deal but the oil drops on the floor bug the crap out of me! what should i do? should i get it checked out by toyota? i have a friend that works there, should be able to help me out....
-omar
rally tarmac 1990 st185
smog7
Postby toayoztan » Tue Oct 31, 2006 6:59 pm
If you're not sure what your'e doing and dont know jack about the alltrac/cars, then having a friend check it out is probably the best thing to do. Otherwise, if you're up to it, just jack up the car slightly, get down under the engine bay and over the engine too, and try to trace back where the oil is coming from. Let us know where and what you find, and we'll try to help you out as much as we can.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby 90TURBO4WD » Tue Oct 31, 2006 7:00 pm
get it checked out
shouldnt be a massive problem if you dont get to it immediatly but be sure your checking your oil level more frequently as you know your going to be losing some.
where is it leaking from
ie front rightside, rear left side........ :shrug:
if you know where abouts its leaking from you can usually figure it out pretty easily
90TURBO4WD
Postby smog7 » Tue Oct 31, 2006 7:31 pm
its leaking mainly next to the front right axle.. might be the transmission im not sure.
ill try to get some better pics up later
-omar
smog7
Postby toayoztan » Tue Oct 31, 2006 9:39 pm
Since that is all on the outside, my first guess would be your valve cover gasket. Check it and you should probably replace it anyway.
Other possibility is oil pan, since that's all on the outside, but then again, it's hard to imagine the oil traveling up as so.
Other possibilities are the cam seals and oil pump seal, however, those are located inside the timing covers, so i doubt it.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby 90TURBO4WD » Tue Oct 31, 2006 9:54 pm
i really doubt its the tranny judging by that pic
might be a valve cover...or oil pan although that oil does look a litte to far up the block... not sure just keep an eye on it.
i have been driving around with a crapped out pan gasket for a while but i just watch the levels alot and keep a rag or cardboard under my car :doh:
90TURBO4WD
Postby hacker_720 » Wed Nov 01, 2006 12:16 pm
+3 on valve cover gasket.
hacker_720
Postby db » Thu Nov 02, 2006 8:11 pm
Alltrac7, double check to make sure the valve cover bolts are tight. I found more than half of mine were seriously loose (though I wasn't leaking oil anywhere). The screw top bolts suck.
Dave
Black 1990 Celica Alltrac
Las Vegas, NV
db
Postby smog7 » Fri Nov 03, 2006 1:01 am
ill get some more pictures of the engine up tomorrow.... the valve cover has some grime on it but not as bad as the stuff in the picture......
-omar
smog7
Postby Highway » Fri Nov 03, 2006 1:11 am
when you get a chance, take it to a carwash and hose off all the crap up in there.
leaving oil on your CV boots wont let them last long.
be careful when tightening the valve cover bolts. try snug.
also, use a 10mm socket and snug the bolts on your oil pan. SNUG NOT TIGHT. too tight may cause leaks......
Cheers! Highway
former car....Red 91 ST185 AllTrac # 666 "SATAN"
Greddy Turbo, Blitz ECU, RC/CS upgrades....+++
now a 97 BMW 840CI...I miss the AT!
Highway
Postby smog7 » Fri Nov 03, 2006 1:20 am
im going to try and clean out most of the oil gunk this weekend..... simple green a nylon brush, some seram wrap, tape and the hose.
-omar
smog7
Postby theUNYTEDone » Fri Nov 03, 2006 8:21 am
i doubt that cellophane and tape will solve your problem.
it'd just make a mess for when you have to change it.
its not for the car, but tape a piece of cardboard to your driveway/garage so that it doesnt seep into the concrete/asphault. my moms been nagging me to do this for months. hehe....
i personally think the leak may be from with the pan or oil pump...its where mine's is from.
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby smog7 » Fri Nov 03, 2006 5:16 pm
the seram isnt going to fix it,,, im just going to use it to cover up some wires when i clean up the engine
-omar
smog7
Postby Stubble » Fri Nov 03, 2006 10:05 pm
You're on the right track - get the engine as clean as possible, then it should be possible to see where the oil is coming from. One thing I've learned is that oil leaks can travel quite a distance, so make sure you check both sides. Another place to leak is the distributor, although that is on the opposite side of the engine.
Brady Ryall
1990 ST185 Red - parts
1990 ST185 Black
1999 Miata
2008 A3 Quattro S-line
Stubble
Postby smog7 » Sat Nov 04, 2006 7:05 pm
well i started to clean the gunk off my car today i noticed that two of the valve cover bolts were loose....... are their any instructions on how to remove the intercooler so that i can check the other bolts and clean off the valve cover?
-omar
smog7
Return to New Member Forum
