Do rotas fit on an st185?
Postby smog7 » Mon Nov 13, 2006 5:52 pm
Just wondering but do rota wheels fit on our cars? if they do anyone have pics?
-omar
rally tarmac 1990 st185
smog7
Postby CMS-GT4 » Mon Nov 13, 2006 6:01 pm
Some do.
Postby smog7 » Mon Nov 13, 2006 6:09 pm
would this fit? i know the size for my car is 5x100 but idunno...
17 x 7.0 +38 4h/5h x 100/114.3
-omar
smog7
Postby CMS-GT4 » Mon Nov 13, 2006 6:13 pm
Yes it would. You might want to read the wheel tire thread though. Too skinny a wheel for the car IMHO.
Postby smog7 » Mon Nov 13, 2006 6:29 pm
i cant find the thread... links :shrug:
-omar
smog7
Postby SuperWhite92 » Mon Nov 13, 2006 6:34 pm
They will fit. Mind if I ask "Why Rota" though?
Shaun
SuperWhite92
Postby smog7 » Mon Nov 13, 2006 7:00 pm
i like the design of a couple of their wheels and they're cheap. i dont see the point of spending 1/4 of what my car cost on wheels.
-omar
smog7
Postby CMS-GT4 » Mon Nov 13, 2006 7:02 pm
Postby db » Mon Nov 13, 2006 7:39 pm
17x7 works fine with a 215/40/17 and maybe with a 225/40/17. 235's are little bit too big. They'll work, but a lot of the tread hangs out the side making me question its reliability in a hard turn.
Just make sure the wheel is a 5x100 or at least a 5x100/114 (dual drilled holes). Pretty sure a 4/5x100/114 doesn't exist on a wheel at the same time.
Dave
Black 1990 Celica Alltrac
Las Vegas, NV
db
Postby darthripley » Mon Nov 20, 2006 8:57 pm
17 x 7 is what i have on my camry actually with a +42mm offset, just to give you an idea.
if you are going to go with a 17" rim on an alltrac i would try to go 8 wide or wider myself...fits the widebody a lot better.
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
Postby theUNYTEDone » Wed Nov 22, 2006 11:51 am
darthripley wrote:17 x 7 is what i have on my camry actually with a +42mm offset, just to give you an idea.
hey ripley...how wide van one go until the tire rubbers start to hit the suspension things?
i remember there were a few people who had to use spacers because of this... :shrug:
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby darthripley » Wed Nov 22, 2006 8:23 pm
Unyted, are you talking about on a camry or an alltrac?
my friend with a v6 s/c 98 camry has 18 x 8 rims with +35mm offset & has 5mm spacers in the rear to prevent rubbing. with a camry the only place you have to worry about rubbing is in the rear, but alltracs are a bit different with the widebody etc.
Female Moderator
darthripley
All Trac Goddess
Postby theUNYTEDone » Thu Nov 23, 2006 7:01 am
i think it was with an AT...there was discussion about what the widest tires able to be run were, and someone chimed in with the spacers bit...totally foggy to me now, though. :doh:
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Return to New Member Forum
