wastegate??
wastegate??
Postby smog7 » Wed Nov 15, 2006 11:53 pm
What exactly does a wastegate do?? and is an aftermarket one really necessary?
-omar
rally tarmac 1990 st185
smog7
Postby db » Wed Nov 15, 2006 11:56 pm
A wastegate regulates boost pressure. It opens and closes to make sure you get the exact amount of boost you want into the manifold.
You need a new wastegate if your old one is bad.
Aftermarket wastegates are needed for externally gated turbos (which ours isn't.)
Dave
Black 1990 Celica Alltrac
Las Vegas, NV
db
Postby smog7 » Thu Nov 16, 2006 12:11 am
so do our cars come with them?
-omar
smog7
Postby Qlynxer » Thu Nov 16, 2006 12:37 am
Our cars have internal wastgates that are built into the turbo. The wastegate pretty much opens up when it senses a certain level of boost. It opens up at that boost level so that exhast energy can bypass the turbo and limit booost. With out it you would overboost untill somthing broke.
Quan L
Santa Ana Ca
Qlynxer
Postby toayoztan » Thu Nov 16, 2006 2:07 am
To add, usually internal wastegate (WG) are operated by an actuator and rod, and an external WG is operated by a spring.
Here's a decent read that shows pictures to help you understand:
http://en.wikipedia.org/wiki/Wastegate
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby smog7 » Thu Nov 16, 2006 3:28 am
i dont see the difference between a wastegate and a bpv or bov.....
-omar
smog7
Postby Qlynxer » Thu Nov 16, 2006 3:51 am
Exhaust gas that exits the exhuast manifold have two paths they can go. Usually they flow into the turbo fins and spool the turbo, once a certain psi of boost is achieved, the wastgate opens and the exhaust gas has another exit to flow thru. Since the exhaust gas bypass the turbo when it goes thru the wastgate, the turbo doesn't make as much boost. A wastgate function is to regulate boost by manaing the amount of exhuast gas flowing thru the turbo. A bov/bpv has nothing to do with exhaust gasses.
Santa Ana Ca
Qlynxer
Postby Gary » Thu Nov 16, 2006 4:18 am
Add to above,
In order for the turbo to function properly, it needs a wastegate (regulate and limit boost).
If it does not function properly, you will overboost or not boosting at all.
BOV/BPV is just an add on component to prolong life of a turbo.
93 ST185
Gary
Postby smog7 » Thu Nov 16, 2006 4:38 am
oooo ok now i get it (sorda). thanks for clearing it up
-omar
smog7
Postby Sleeka_89 » Thu Nov 16, 2006 10:33 am
I might as well add in a little while im here :D
So like everyone else has said the wastegate is to regulate the boost that the turbo can produce through redirecting exhaust gases.
A bov on the other hand vents charged intake air. Once the turbo sucks in the air, it gets compressed and forced into the motor. When you back off from the throttle theres a "butterfly" in the throttle body that shuts restricting air to go in. Now you still have all this pressuried air trying to get into the motor but since the throttle is closed its got nowhere to go expect where it came from... the turbo. This cause that flutter noise that you hear when you back off from boost. This "flutter" can shorten the life of the turbo because of the volient change in air direction, and on a performance side of things can create unwanted lag, since the air almost stalls the turbine or slows it down alot and then you have to re-spool it in the next gear. With a bov in place it vents that air away from the turbo thus saving the air rushing back through the turbo. No more lag, no more turbo worries :D
A man who shoveled snow for an hour to clear a space for his car during a blizzard in Chicago returned with his vehicle to find a woman had taken the space. Understandably, he shot her.
Sleeka_89
Return to New Member Forum
