gas gauge...
gas gauge...
Postby smog7 » Sun Nov 19, 2006 8:12 am
well i just got my car about a two months ago, and i never wanted the gas to run low so i never let go past the 1/4 tank mark. but today i did, and for some reason my low gas light only turns on when i am a stop...but when im driving the gas mark seems to go up... is this normal? i dont want to rund out of gas in the middle of nowhere.
-omar
rally tarmac 1990 st185
smog7
Postby Sleeka_89 » Mon Nov 20, 2006 5:30 am
when you start running low the fuel light comes on for a few seconds then turns off just to let you know to fill up. It will keeping coming on then switching itself off as you keep driving, this is normal. If you keep driving for a while the fuel light will eventually go on and stay on, this is where your starting to get pretty low and should start thinking about getting to a fuel station. When you fuel light comes on for the first time you should have close to about 10L in the tank left which if you drive conservatively should be about 100km. I've driven my car for just over 100km with the fuel light on and it still made it to the station. Dont worry about running out of fuel, you would have to be driving for a long time on the light to run out and even then theres a way you can check how long you have left. Go hard around a corner and keep the accelerator nailed, if it misses at all then your almost out, you might have 10km up your sleve. Dont ask me how i know this :D
A man who shoveled snow for an hour to clear a space for his car during a blizzard in Chicago returned with his vehicle to find a woman had taken the space. Understandably, he shot her.
Sleeka_89
Postby muneo » Mon Nov 20, 2006 4:52 pm
The float that measures the gas level is not centered on your gas tank. Its in the rear passenger corner of your tank. This means, if your on a upward slope that leans to the left of the car, your tank will show much higher than it really is. The gas light flickering on and off is basically adjusting to your cars general position in the X,Y and Z axis.
With a quarter tank you can get the gas light to go on if your on a downward hill that leans the car over to the right. Of course, the more level and steady you are, the more accurate the meter reads.
If that light stays on continuously no matter what position your car is in, you have a roughly 2 gallons left. Our light warns us early. My light comes on when I have about 4 gallons of gas left. Thats 100 miles of steady highway driving!!!
Ex-185 Owner
muneo
Postby smog7 » Mon Nov 20, 2006 5:15 pm
ok, so i should only start to worry about getting gas when the light stays on...
-omar
smog7
Postby db » Mon Nov 20, 2006 5:30 pm
Yep, and you'll find that you still have 2-4 gallons left.
Dave
Black 1990 Celica Alltrac
Las Vegas, NV
db
Postby Whyte185 » Tue Nov 21, 2006 10:32 pm
shouldn't you gas up a turbo car when your around a 1/4 tank left anyway b/c when your tank starts getting low you get less fuel pressure i've heard, please correct me if i'm wrong and in a turbo car you wouldn't want lower fuel pressure
Whyte185
Postby 2RM » Tue Nov 21, 2006 10:52 pm
Whyte 185 you are wrong.The fuel pressure will not change until the fuel pump has something to suck on or the voltage to the fuel pump drops for some reason.
2RM
Postby Whyte185 » Tue Nov 21, 2006 11:19 pm
alright this is just something i'd heard was wondering if it was true, thanks for the answer 2RM
Whyte185
Postby theUNYTEDone » Wed Nov 22, 2006 11:49 am
my gas gauge has never been right since i bought my car. i know i've said it in some other posts...but i'll fill up, then about one mile (yes, ONE mile) after the gas station, i'm at 1/2 a tank...stupid, but i just fillup/topoff at about 100 miles, anyway....dont fancy the idea of dropping the tank/getting to the wires JSUT for this to be fixed.
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby Sleeka_89 » Wed Nov 22, 2006 1:03 pm
im not 100% on the 185, but on the 165 the fuel sensor is just under the rear seat. Just pop the seat out and its sitting right there held in with a couple of screws and a plug, i'd just say the sensor is getting suck giving false levels, try replacing it and see how you go :D
Sleeka_89
Postby theUNYTEDone » Wed Nov 22, 2006 7:23 pm
rear seat, eh?
well, i just remember the wires n plugs n such being right at the fuel tank (next to the spare tire)...i'll need to refer to my almighty BGB for this one...hope it's actually easy to get to!. thanks!
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby Rick89GTS » Thu Nov 23, 2006 2:40 am
No matter how often I fill up, my gas light comes on too soon! :lol:
Rick89GTS
Return to New Member Forum
