Instructions on how to remove tail light?
Postby smog7 » Mon Nov 27, 2006 10:40 pm
I need some help taking off my driver side tail light from my 1990 alltrac.. can anyone help?
rally tarmac 1990 st185
Postby daveryan » Mon Nov 27, 2006 11:13 pm
I'm too lazy, to type it out, but here is some copy/paste from this Celicatech thread. Props to the original author. Simple really, just try not to damage the light in step one.
Step one is to remove the amber (corner) cover, which can be done by inserting a flathead screwdriver into the seam between it and the main portion of the tailight. It pops loose, then you disconnect the socket from the cover.
Step two: remove the two screws that were hidden under the amber corner light cover.
Step three: find the plastic cover on the top of the light assembly (might be hidden by the trunk's weatherstripping). Pop it off and there's a screw to remove.
Step four: pull the taillight assembly gently out of the clips that should be holding it on. Pull straight out, no twisting.
If you need a diagram, consult the owners manual if you have one.
1990 ST185
Return to New Member Forum
