Clutch master/slave cylinder?
Postby CeliKhanh » Wed Dec 06, 2006 6:10 am
the shop where i dropped my car off to get the clutch installed said i need to replace my master and slave cylinder, becuase when i depress the pedal, there is very little pressure near the point where its near the floor
is it true that i need to change them?
should i go w/ OEM or Aftr Market or doesnt really matter at all?
thz
8) khanh
CeliKhanh
Postby toayoztan » Wed Dec 06, 2006 6:28 am
Well first, i would ask them how exactly they went about bleeding it.
Then I would wonder how they determined both the slave and master are out if there isn't any pressure? If there isn't any pressure, i would suspect master first. If there is pressure but the slave rod isn't moving, i would then suspect slave. I mean, it COULD be both, but i would replace the master first if i had to replace anything at all.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby CeliKhanh » Wed Dec 06, 2006 7:10 am
just teen bit of pressure when near the floor, and pedal gets stuck, press a cuple time and it'll release but not so much.. mite as well replace both i guess
so OEM/aftrt markter/ either or?
CeliKhanh
Postby hacker_720 » Wed Dec 06, 2006 12:24 pm
I belive people have had a problem with aftermarket ones, I would stick with OEM if you could.
BOTTLE ARE FOR BABIES...REAL MEN GET BLOWN
1990 ST185 2.2Lt
hacker_720
Postby gt4tified » Wed Dec 06, 2006 12:49 pm
hacker_720 wrote:I belive people have had a problem with aftermarket ones, I would stick with OEM if you could.
times 2
gt4tified
Images: 5
Postby CeliKhanh » Thu Dec 07, 2006 1:09 am
k thanks, and i was going to get aftr mrkt ones ssince they're half the price
anyway how much does the labor to change them anyway? so i know i'm not getting ripped :(
man, so many crap has been discovered once the tranny is off, like power steering is leaking, the differential is leaking, now i'm lo0king for a gasket for it and the shop is asking for way 2 much just for the labor to change that gasket .. is It REALLY that hard to change the differential gasket? i mean the tranny is alrdy off, any1 know ow much for labor that should cost also?
thanks alot!!
CeliKhanh
Postby gt4tified » Thu Dec 07, 2006 3:14 pm
CeliKhanh wrote:k thanks, and i was going to get aftr mrkt ones ssince they're half the price
thanks alot!!
Actually, changing the cylinders are pretty easy....you just need the right tools....the master cylinder is a bit tricky because of the big ass steering wheel that toyota decided to put on our cars. The master is attached to the firewall by studs I think.
If you have the tools, do it yourself and use the money to replace the hard line from the master to the slave cylinder with a stainless steel braided one...and you'd have to get a pal to help you bleed the line after.
gt4tified
Images: 5
Postby CeliKhanh » Fri Dec 08, 2006 3:14 am
good idea thz 8)
CeliKhanh
Return to New Member Forum
