Light on with open door.
Postby smog7 » Mon Dec 11, 2006 4:28 pm
Just wondering if it is a common problem in our cars for the little door light switch thing to go bad? ive tried messing with mine but the light never turns on when the doors are open, the hatch does though....
-omar
rally tarmac 1990 st185
smog7
Postby db » Mon Dec 11, 2006 5:47 pm
My driver's switch went bad, and always thought the door was open. I had to disconnect it and will need another one at some point in time.
Dave
Black 1990 Celica Alltrac
Las Vegas, NV
db
Re: Light on with open door.
Postby toayoztan » Mon Dec 11, 2006 5:56 pm
alltrac7 wrote:Just wondering if it is a common problem in our cars for the little door light switch thing to go bad? ive tried messing with mine but the light never turns on when the doors are open, the hatch does though....
It's been common with me. And even other celicas i've ran into. For some reasons, the sensors just get bad, corrode, whatever. Just buy some new ones from Toyota, they are the same from celica to celica within the gen.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby silence » Mon Dec 11, 2006 6:31 pm
I have the same problem!!!
I changed both door sensors, and my problem continues!
06 WRX, 90 Celica Alltrac & 88 BMW TURBO 325is
http://www.youtube.com/watch?v=Ei5P9LfLRdg
silence
Postby SuperWhite92 » Mon Dec 11, 2006 7:10 pm
Most of the time (not all of the time), you can just remove the rubber cover to the switch, unscrew the switch, pull it out as far as you can, and give it a good cleaning with WD-40 and reinstall it. If that doesn't work, you can replace them with new ones or check the wiring itself.
Shaun
SuperWhite92
Postby 90TURBO4WD » Wed Dec 13, 2006 2:37 am
the bulb is good right???
:shrug:
i've replaced a couple switches before doing the easy thing and check the bulbs :twisted:
JEFF
'90 ST185-project car
'91 ST185-parts car then to be rebuilt
'00 Chev 1500-Daily Driver
up in the great white north
90TURBO4WD
Postby smog7 » Wed Dec 13, 2006 2:39 am
yeah the bulb turns on when the hatch is opened. unless their are different bulbs for the door and for the hatch...
-omar
smog7
Postby 90TURBO4WD » Wed Dec 13, 2006 2:45 am
so the bulb on your door (light under the red cover on the door) is not working and the bulb on the ceiling is working when you open your hatch. or do you mean the light in the back of the hatch
there is three different types of lights that turn on the doors, the ceiling and in the cargo area, which isnt working. on mine, i think (cant remember perfectly havent driven it in a bit) both door lights and the ceiling light turn on hen you open the door, and the cargo light turns on when the hatch opens.......i cant remember :shrug: but this is what i somewhat remember
JEFF
90TURBO4WD
Postby smog7 » Wed Dec 13, 2006 2:52 am
when i open the doors, nothing turns on. when i open the hatch only the back cargo light turns on.... also not even the little red open door warning car light turns on when i open the doors, but it does turn on when the hatch is open.
-omar
smog7
Postby 90TURBO4WD » Wed Dec 13, 2006 3:04 am
yep that would be the switch on the door.
really easy to replace one bolt from what i remember.
i cant remember what i paid at toyota for them but i think it was around 25bucks but its been soo long i cant really remember sorry but ya im sure its your switch especially since that dash light or door dinger isnt going off :smokes:
JEFF
90TURBO4WD
Postby at3619 » Wed Dec 13, 2006 3:58 am
90TURBO4WD wrote:yep that would be the switch on the door.
Not positively
I thought it was my switch. But it wasnt. Check out the wiring diagrams. Its frightening... I tried to troubleshoot the circuit but gave up after frustration. It worked fine till i installed my alarm :cry:
It really pisses me off that my lights dont auto shut off anymore...
I will fix it, just have to work the lazyness out of my system. So what im saying is ill never get it fixed....
Josh
-2 Twin Super Red 88 Alltracs (RIP my sons...)
-One sweet pile of all trac parts!!!
-00 Celica GTS(B18 Eater)
-1985 Volkswagen Vanagon Westfalia Camper AKA "turtle"
Converted to Syncro(4WD)
Subaru SVX 3.3L H6 swapped!
at3619
Postby 90TURBO4WD » Wed Dec 13, 2006 5:31 am
but if that started after the alarm was put in, the alarm could be the culprit.
but of course it could very well be something else :shrug:
JEFF
90TURBO4WD
Postby theUNYTEDone » Wed Dec 13, 2006 6:09 am
:lol: if i toggle the little rubber thing, then itll work if i get it at the right angle. pass side door is totally unfunctional...it sucks too, because my alarm is run ENTIRELY off of whether or not the doors open. seems to be the only thing that triggers it. :x
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby at3619 » Wed Dec 13, 2006 6:23 am
90TURBO4WD wrote:but if that started after the alarm was put in, the alarm could be the culprit.
it is the culprit :wink: Does not change my point that he could be getting the same symptoms without the door switch being the cause. My alarm was the cause, but after i took it out the problem was still there. Which means something in the circuit is bad now, because of the alarm...
Josh
at3619
Postby 90TURBO4WD » Wed Dec 13, 2006 11:07 pm
yikes shitty deal man. i sorta have the same problem except my alarm burnt itself out. somewhere in the alarm harness something shorted out and that fried the computer for the alarm. so i am having to trace the problem now. :shoots:
JEFF
90TURBO4WD
Return to New Member Forum
