3GSTE non-interference engine?
Postby WarTowels » Tue Jan 09, 2007 3:22 pm
My Celica GT as far as I know has a non-interference engine, I was wonder if the 3gste is also non-interference. :D
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby hacker_720 » Tue Jan 09, 2007 3:42 pm
yup
BOTTLE ARE FOR BABIES...REAL MEN GET BLOWN
1990 ST185 2.2Lt
hacker_720
Postby WarTowels » Tue Jan 09, 2007 3:44 pm
Yay for Toyota. What other toyota engines are non-interference?
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby Gary » Tue Jan 09, 2007 4:23 pm
Most Toyota engines are non-interference.
Interference engines : 1MZFE, 3MZFE, 2UZFE, 5VZFE, and some diesels, ...
93 ST185
Gary
Postby ___Scott___ » Tue Jan 09, 2007 5:15 pm
I've been told that Toyota engines which use timing belts are non-interference. Toyota engines that use timing chains may or may not be interference.
I'm not 100% sure it's true, but I haven't seen a case where it isn't yet.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby theUNYTEDone » Tue Jan 09, 2007 6:05 pm
can it be safe to say that newer engines are non?
my stepdad was speakng about one of his motors blowing due to a broken Tbelt. he said mine would do the same...but i guess not, after reading this.
are there certain pros/cons of each?
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby Gary » Tue Jan 09, 2007 6:39 pm
1mzfe is newer than 3sgte or 5sfe, but the 1mzfe is interference engine. 3sgte and 5sfe are not.
I don't see other pro/con except that the pistons will not hit the valves in non-interference engine when timing belt breaks.
93 ST185
Gary
Postby theUNYTEDone » Tue Jan 09, 2007 9:10 pm
hmm...thanks gary. up until jsut then ive never even heard about interference/non...
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby built2run » Tue Jan 09, 2007 11:33 pm
so what happens if one gets very high lift cams?
ST165, black: parted and gone
ST165, white: sold to friend
built2run
Postby theUNYTEDone » Wed Jan 10, 2007 9:51 am
built2run wrote:so what happens if one gets very high lift cams?
one gets valve work done.
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby WarTowels » Wed Jan 10, 2007 2:18 pm
Thanks for the replys!
I've decided not to do my timing belt until it breaks :twisted:
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby theUNYTEDone » Wed Jan 10, 2007 10:19 pm
ehh...dont give in to marks of a poorly formed gt4 owner. take care of your car and maintain it correctly.
but of course i knew you were joking. :wink:
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby WarTowels » Wed Jan 10, 2007 10:37 pm
I don't have a GT4 :D
I haven't even hit 130,000 so im not terribly worried.
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby eddie_gt4 » Thu Jan 11, 2007 5:59 am
interesting story: I know one ST185 CS owner who bought his car with broken timing belt... according to him, only 2 valwes "survived" :shock:
'90 Toyota Celica turbo 4WD ST185 - ex
'96 Toyota Celica GT-Four ST205 - now
eddie_gt4
Images: 11
Postby Gary » Thu Jan 11, 2007 6:57 am
eddie_gt4 wrote:interesting story: I know one ST185 CS owner who bought his car with broken timing belt... according to him, only 2 valwes "survived" :shock:
Does it have stock cam, piston, rod, crank, etc..?
93 ST185
Gary
Return to New Member Forum
