alltrac7":18p32f9k said:i cant even get the plug boot off
SuperWhite92":1o85qb2n said:alltrac7":1o85qb2n said:i cant even get the plug boot off
You're kidding, I hope.
You just grab the boot (Not the wire) and pull it up. If it's tough, you might have to wiggle it a bit too.
BLOWNTACO":2a8gpu80 said:Hell, if they're that stuck, go and get some new wires and destroy the old ones. A little trick to keep that from happening, while you're at the parts store get some dielectric grease and put a small amount in the boot. Lubes them up nicely and keeps them from causing headaches when its time to replace the plugs again.
