camry dx project
zaluss
Member
Pulling the head really sucks. The cams block the headbolts and removing the cams is a chore in itself because the cams are driven by a single cam gear and have to be removed carefully to make sure both gears are synced on removal. They have little notches to let you know how to match them. This is the only picture I had saved of the
Top
