Sounds like you're looking for a beater. If your looking for near perfection.. Southern car. ZERO RUST. Interior/exterior restored 6 years/20k miles ago. Castrol decals added last year and easily removable. Parts list too long to list here. Genuine Toyota parts used when possible. $20k.
Without decals:
The List:
Engine:
JDM 3SGTE from clip. 36K miles, new seals, belts, pump, timing belt etc.
CT20b turbo: black powder coated compressor
TVIS butterflies removed, holes heli-arced, port matched.
Valve cover black powder coat
Intake manifold black powder coat
RC/CS water to air intercooler, black powder coat
RC/CS proper motor mount and hard pipe water lines
RC/CS proper starter(smaller than US for hard pipes clnc)
ST205 pump/with relay
ST205 front heat exchanger/shock mounted
TRD plug wires
Exhaust manifold black ceramic coated
Turbo heat shield black ceramic coated
Custom cold air intake with K&N filter behind fender liner
3 inch SS turbo back, mandrel bent exhaust with oversized flex section
Random Technologies catalytic converter
Magnaflo SS muffler
Blitz Access ECU
Blitz type R dual solenoid boost controller
Greddy turbo timer (not connected)
Driveline:
XTC 12lb chromoly flywheel
Clutch Masters stage one clutch
SS Braided clutch line
Updated genuine Toyota synchro's
All CV joints rebuilt
RC/CS Torsen limited slip differential
Suspension:
TEIN coilovers
Whiteline adjustable swaybar
Wheels/Brakes
Enkei 17x8 +35 wheels at 15.5 lbs each. x5 (incl. spare)
H&R 25 mm rear spacer
Wilwood Front and rear 4 piston calipers, forged. Properly sized for correct bias. Custom brackets.
Wilwood two piece rotors on custom hats. OEM parking brake remains.
SS braided brake lines
Currently Falken RT 615's , 225/55R17
Body
PPG gloss black, glass, bumpers, wing, handles all removed for paint
Windshield replaced at paint
RC/CS hood, bumper including accessories for each purchased new
RC/CS proper windshield squirters (no small feat finding those)
93 rear tail lights
JDM front corner lights
RC/CS engine undertrays, modified to accommodate ST205 heat exchanger
Modifications to OEM
Rear seat removed(new leather covered ones in storage)
Custom cover with OEM matching carpet with access panels
Battery/ stereo amps reside under access panels
Optima "red top"
1/0 oxygen free cable
ICE
Kenwood Excelon x711 head unit w/ 5v output
Blitzsafe iPod adapter
Coustic XM-3 crossover
Audio Art bass amp
Precision Power 4 channel full range
Kicker RMB 8's in doors
Memphis Audio component fronts
Memphis Audio 2 way carbon fiber rears.
Interior
Leather seats recovered using Katskinz leather
triple gauge pod with boost, EGT, Innovate Motorsports AFR
TWM short thro shifter
TRD shift knob
There's more, I'm getting tired!
gt4rcman at gmail
