4th gen 3sgte to st165 issues?
Postby overboost » Wed Sep 23, 2015 9:04 pm
Hi, I'm from Guatemala Central America, I have a st165 and I want to go with the st215 engine, I really don't know if I can do the swap, any help will be great, thanks
overboost
Re: 4th gen 3sgte to st165 issues?
Postby Awesome-Trac » Wed Sep 23, 2015 9:15 pm
Main thing is the wiring which is the problem for everyone doing swaps so what you need to do is get a motor with harness and ECU then convert the Onto the 165 one. Second would be motor mounts as well cause the st215 won't work on the 165 chassis
•Daniel
Awesome-Trac
Postby zaluss » Wed Sep 23, 2015 9:18 pm
overboost wrote:Hi, I'm from Guatemala Central America, I have a st165 and I want to go with the st215 engine, I really don't know if I can do the swap, any help will be great, thanks
Yes it is possible. You will need to pickup a ST205 trans (recommended) or use your existing ST165 transmission. The block itself will bolt on as well as the trans with all the existing mounts. Since the factory ST215 intercooler is ATA, you will need to either cut the hood or change to a FMIC. I also recommend Wiregapinc.com to do the wiring for you if you don't want to do that part.
ST162 (FWD) w/ ST215 swap http://www.celicatech.com/forums/showth ... highlight=
My own ST165 to ST205 swap viewtopic.php?f=44&t=50558
Goodluck!
zaluss
Return to New Member Forum
