Hello from france
Hello from france
Postby tofe_auto » Sun Oct 11, 2015 2:58 pm
hi everyone,
i m Christophe, from France
got my first St185 rally car 2 years ago , exchange against a bmw compact rally car
it is a group A car, with engine rebuilt in 2013 (300 hp ), dogbox serviced in 2014 with new competition clutch, all the electrical harness made in dec 2013 , front brakes upgraded with 4 pot caliper and 330 mm disc, coil over, .....
we take part to 2 rallyes in 2014but had problem with clutch at the first one, after 5 stages on 6 , wich was at least a great day, after 7 years without rallying ! for the second rally, we had a test day one week before, whot let us find a problem with the wastegate, so the car was perfectly running , but after the first service park , the engine began to work badly, heating a lot , and losing power ! we decided to retire after a very bad first stage .
when we dismantled the engine, we discovered that the cam belt pulley tensioner wasnt fitted correctly, and it caused the belt had probably moved from its rigt position , probably a few tooth , not enough to break al the engine !
camshaft and head had to be changed ! we now are in process to finis the engine, and will probably run the car in november to check what is in the Sybele ECU .
i Wonder if i will run the car in historic rally in 2016 or stay in modern rally
i will try to post some pics of the car in a next post
happy to discuss about this powerful car, i m sure we had bad chance with i until now , but the future will be better !
tofe_auto
Images: 4
Re: Hello from france
Postby Domspun » Mon Oct 12, 2015 3:42 pm
Salut Christophe!
Bonjour du Québec! :D
Domspun
Postby rallygarage » Tue Oct 13, 2015 10:59 am
Hello. In France you are close to some good rally parts companies in UK. Lewis Rally Sport and Darrel Staniforth. They have many good solutions for rally.
rallygarage
Postby Locker » Tue Oct 13, 2015 3:46 pm
Welcome! Cant wait to see pictures
90 ST185
Locker
Postby tofe_auto » Sat Oct 17, 2015 2:22 pm
hi everyone, just add some pics in my gallery
tofe_auto
Images: 4
Return to New Member Forum
