New to 88 all Trac st 165
Postby Dj1412 » Mon Feb 15, 2016 5:13 am
Recently picked up 88 st165
Few issues
Can't find correct front brake pads for calipers all part stores have the wrong ones
Turbo hits 1 good boost than goes into a safe mode or no boost mode but if you cycle ignition it restores back to normal
Can u fit fwd st165 st 185 or 205 full strut asemblys struts calipers and rotors everything on 88 st165 all trac
Will cv axles fit and or are the there other cars that run same or better full struts asemblys
Dj1412
Re: New to 88 all Trac st 165
Postby zaluss » Mon Feb 15, 2016 11:59 am
Dj1412 wrote:Can't find correct front brake pads for calipers all part stores have the wrong ones
I went to the dealer on these. Part number 04465YZZA2. Only $35 from Lithia.
Dj1412 wrote: Turbo hits 1 good boost than goes into a safe mode or no boost mode but if you cycle ignition it restores back to normal
Any codes?
Dj1412 wrote:Can u fit fwd st165 st 185 or 205 full strut asemblys struts calipers and rotors everything on 88 st165 all trac
ST165 front struts are unique. You can replace the front inserts with aftermarket. Rears are sealed. I think you can fit ST185 front calipers/rotors but not ST205 ones due to balljoint clearance and some other issues.
zaluss
Postby Dj1412 » Mon Feb 15, 2016 1:25 pm
Yeah no codes
Thanks for part number I'll check with dealer
Dj1412
Postby ___Scott___ » Mon Feb 15, 2016 6:24 pm
For brake pads, I run Porterfield R4-S pads. They are remarkably good pads on the street, even in very cold temperatures. I find they transform the mediocre ST165 brakes into something I can live with. I've been buying them from http://www.lpiracing.com/ but I see that twosrus sells them just a bit cheaper:
http://twosrus.com/catalog/index.php?cP ... =2a&page=2
For the front, you want the AP437 pads.
For the rear, you want the AP325 pads.
For the boost issue, either dial your boost down a little or do a search for "boost cut defender."
If you are still running stock head bolts and the stock head gasket, I advise to live with less boost. I have my boost set to just below the fuel-cut level and I still have encountered a leaking head gasket. I'm not loosing coolant, but the cooling system is being pressurized by combustion gases leaking into it. I'm facing a gasket&studs project in the not to distant future.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Return to New Member Forum
