New Member
New Member
Postby tractor1 » Wed Feb 24, 2016 10:47 pm
Hi I am a new member and was trying to get part numbers for the rear control arm bushings on my 1990 alltrac. I though someone said you could use bushings off a Camry of the same year? Trying to make sure I can get parts before I take apart. The bolts are rusted solid will have to cut/heat off. Looking for all the bushings. Would like to go as close to stock as I can.
tractor1
Re: New Member
Postby Corey » Wed Feb 24, 2016 11:06 pm
Hey, welcome to the club.
This is a great thread regarding the subject with good photos and insight on replacing these bushings.
viewtopic.php?t=21366
As for part numbers, you can use the site www.toyodiy.com to crosscheck them between models.
Corey
Corey
Images: 50
Re: New Member
Postby tractor1 » Wed Feb 24, 2016 11:41 pm
Thank you.
tractor1
Return to New Member Forum
